jsinher3 work in progress thread
#26
Re: jsinher3 work in progress thread
heres the video for the ls cluster swap test
and here is it fully working with the electric vss for the speedometer minus the dam brake light i cant figure it out... ignore the check engine light its code 9 and i cant seem to figuere out the source of the problem yet...
#27
update
soo i got the reverse light to work, it was a broken ground ugh haha... i also ordered a ac delete plug and put it on today along with the bumber..
#32
Well I came up on a deal, complete b16 motor for 250 off craigslist, bad thing two cylinders have low compression... Well im hoping to take it apart see what's wrong and start a rebuild
#35
Yes, i just want to drive it a little first. Make
Sure i dont burn any oil. Then I have a set
Of stage 2
Cams to dump in. And maybe boost but idk yet.
Of stage 2
#38
#40
update
picked up a si rear sway bar from my cousin for free =D
#42
Rebuild it man! Im making slow progress with mine. Got my mounts on just waiting on a driver side bracket from a da.... Then ecu. Then i get to hear where all my hard money went towards
#43
update
havent been on in awhile due to a tragic lost in my family and school but i have some updates on my build... i ended up selling my b16 motor and purchased a jdm b18c block and slaped a b16 head aka "poormans type-r" with a jdm lsd b16 tranny.
i am now in the process of buying the major and most expensive parts to start the swap so far this is what i got:
innovated hydro billet mounts
hush hydro conversion kit
Carlos Zapien(look him up on FB) hes also a member in HT crzguy i think.. obd1 tucked b-series plug and play harness
dc2 rear trailing arms
im back in school and so im not working as much... so this might be the biggest update until after school lets out.
#44
Nice, I am liking this, Kind of like my crx I am still working on but I'm doing a straight b18c swap. Look forward to seeing progress even if it is slow. Love how clean the engine and box is as well, should look good in your clean engine bay!
#47
thanks
i got it from a member here i forgot his username but heres his fb name carlos zapien
#48
more stuff piled up on the corner of my room. picked up an s300, plm-rmf header, and accord ex calipers (same as the type-r calipers).. going to try to start refurbishing my brake set up and hopefully next month ill put the hatch away to start the build... fingers crossed
some pictures
some pictures
