ITR 5 Lug on an EF?
Re: ITR 5 Lug on an EF? (IntegraTypeRice)
i guess it could be possible maybe im not completely sureif u take the rear brakes and all from one and put them on the rear disc trailing arm from a 91 crx si or 90-93 teg trailing arm i think u could do the back that way the front i would think u would have to do the bigg brake conversion of the ex or teg and swap the type r front brakes on some how like i said im not sure about it id have to see the two next to eachother
I have heard that with the exception of the shocks/struts and the LCA's it is a direct bolt on. but that was from a guy who was trying to sell me a setup, so be careful. In 3-5 weeks I will try this with the CTR setup, wich is supposed to be identical, and will let you know if it works out.
New User
Re: ITR 5 Lug on an EF? (Trinity)
" Owning a type-r is like being married to a southern woman, you have to beat the **** out of it before it does anything" - ME!
Its really easy actually. Just change the outer tie rod ends for the front and the rest of it bolts up.
Modified by crXBoy69 at 7:38 PM 11/5/2003
Re: ITR 5 Lug on an EF? (crXBoy69)
i don think the trailing arm bolts to the ef parts i think u would have to take the whole thing apart or is that ur car? i thought the newer teg had a diff trailing arm
Re: ITR 5 Lug on an EF? (hot_EF)
dude what did you just say? did nobody graduate from junior high? what ever happened to puncuation?????
Re: ITR 5 Lug on an EF? (mini-cRx)
Its really simple. The only thing you need other than what is on the CRX is 94+ integra outer tie rod ends. The rear trailing arms are the same. Just change the whole trailing arm, it bolts up to all the crx control arms. For the front just put on the Type R spindles and the 94+ integra outer tie rods. Then just do up the bolts and bleed the brakes.
[Modified by crXBoy69, 7:50 PM 11/21/2001]
ok here is my question i want to do this after seeing that car. now i want a TEIN H/A supension on my car and i know i need the crx 88 suspension or a typpe r rear supension. what i am trying to say after doing all that what else would i need so i can still put my tein on there
Yes, but get all parts
Front: is a bolt-over
Rear: you will need to swap the ITR trailing arm as well but is not a bolt-on
Note: except change in track rear/front
Re: ITR 5 Lug on an EF? (Mugenblkgsr2000)
Dont do it look at this car it doesn't have it.
Re: ITR 5 Lug on an EF? (jdmB18hatch)
Haha, Rotas. Yeah, sure. Those are authentic 16" Spoon rims. That used to be Sheng's (jdmhondaparts) car. Now it belongs to a guy in NY. I think he goes by the screen name SINSI or something like that. He frequents clubsi and this board I believe.
Re: ITR 5 Lug on an EF? (97TypeR_9)
He sold those spoon rims then baught some rotas. Sold the rotas and then got somthing else. But now the new wheels that he is getting are the Volk CE28N's in Gold.
[Modified by CR-X, 9:41 PM 12/15/2001]
