interior lights and corner lights wont turn on?
my lights were working just fine but i decide to run cables connect from my corner lights to my bottom lights the ones that blink so they would stay on and turn on when i would turn my interior lights on well i got it going good and it looked good to but once i turn the car off and it turn it back on my interior lights and corner lights wont turn on anymore?
i changed the fuse and they still dident work but once i started driving it on a bump they turned on?? then turning the car back on they dident turn back on what so ever?? any help would be nice |
Re: interior lights and corner lights wont turn on?
maby im pulling to much power from the corner lights?
i disconected the lights also to see if that was the prob. but they wouldent turn on after i disconected them :( |
check the wiring. If you hit a bump and they turned back on you might have something loose in the wiring.
thats excatly what i was thinking...ima have to check that in the mornign..
but why would connecting the bottom lights caseu the interior lights to shut off? |
okay i disconected all both corner lights and aswell as the bottom ones and the dash lights turn on now
ohh and i forgot to mention that both bottom lights and the left corner light is connect to the right corner light... the reason for that is the left side dosent have the plugs or wires to connect to the corner light so im using the right to power all the other ones.... do you guys think its pulling to much power thats why they shut off? |
bump
yea man that sounds like you have too many lights connected to one wire
Sounds like a dshort, I'd go back and redo everything
How about we start wit MM&Y of car along with trim level..
Depending on that your front side markers may be controlled by the ICM turning them on with park/interior/ head lights, blinking them off for signals when lights are on and blinking them on for signals when lights are off, connecting your front park lights and them together especially if only on one side is going to interfere with the ICM, sounds to me like that is what is happening. Also not sure exactly what you are trying to do???? 94 |
