Brake bleeding problems
Hello ht, I'm having some problems bleeding my ef after replacing pads and shoes. The worked fine before and then I went to replace the old dirty brake fluid and now somethings messed up. I was starting to replace the fluid by cycling It out of the system and then the pedal went to the floor. The problem is I am not getting any fluid out of the breeders. (Bleeders have been removed and cleaned and are not clogged). I don't have any leaks and have tried to pumping with the bleeders removed and still nothing. I think that the master went bad or it got clogged, has anyone had this problem before or have any suggestions?
Re: Brake bleeding problems
Keyboard Humorist
If your assistant was pushing the pedal to the floor during bleeding, it could have damaged your brakes.
You are supposed to only press down about 2/3 of the way and then stop.
All the way can extend the piston in the master cylinder beyond it's normal travel causing damage to the seal.
what 4drEF said.
if someone new is helping, I always put a block of wood under the brake pedal for them. that way they can't go apeshit and ruin my master cyl.
they've probably rolled the orings off the shaft or something like that.
good thing i keep my friends at arm's length lol.
Hand Held Brake Bleeder Tester Set Bleed Vacuum Detector Pump F/ Car Tool Kit | eBay
correct me if wrong but doesn't the $30 vacuum pump bypass this issue?
it's definitely cheaper than the last friend who borrowed money that i have yet to see.
plus it works on my hydraulic clutch too and certain sex toys that
someone had delivered to my house, god bless whomever arranged that!:whistle:
slagman, not necessarily, a master cyl can be bypassing internally without a leak evident. fluid would flow between chambers rather than flowing outside where you can see it. It can also leak back inside the booster, so a leak like that won't be evident right away.
did you wipe the packing oil off the new rotors? how many miles on the new pads? it takes about 200-300 miles for new pads to 'bed' properly. lastly, not all pads are created equal. some pads are just crap, and it isn't always the cheap ones. I use a really cheap organic pad on my daily, and it grips like none other - but makes a mess of dust doing it. Some of the ceramics make no dust at all, but also don't stop either.
Finally, is your brake pedal dead firm? A leak is indicated by a sinking pedal. So you should be able to stand on your brakes for a full minute, and have no movement in the pedal. If you feel the pedal getting away from you, you either still have air in the system or a leak somewhere. A bad master cyl usually is most evident when the weather is warm and you find you have to press further and further down to maintain constant braking (like in an auto car at a red light... you keep your foot on the pedal, but the car after a min starts to creep forward).
tamboo, I haven't honestly had a ton of luck with vacuum bleeding. I have a mity-vac, and I do use it. But there is no replacement for having an assistant pump while you bleed. I've contemplated pressure bleeding too, whereby I force fluid back from the caliper into the master cyl reservoir and then extract from the master cyl, but I haven't done it. Seems messy, but highly effective I would think. My mountain bike is like that, you fill through the caliper bleeder and dump from the brake handle.
eh9deux
17
06-13-2011 07:33 AM
