IACV for ZC
Old 09-14-2015, 05:52 AM
hspeck's Avatar
Default IACV for ZC
I need a new IACV for my D16A9(or ZC in some countries), but it seems that new ones are not available.
Anyone knows the OEM part or any other substitute?
Thanks a zillion!!
Old 09-14-2015, 09:27 AM
jlicrx's Avatar
Default Re: IACV for ZC
the OEM part no. is 36450-PP4-E01
the same part is used on the 88-91 Civic/CRX D16A6 and the 88-89 Integra D16A1
Old 09-14-2015, 05:24 PM
hspeck's Avatar
Thanks, but I do have the part number.
However, the item is no longer available from Honda.
I was thinking it might be generic with some other cars , eg manufactured by Denso, Keihin etc and if it was, what was the original manufacturer part number...
Also, my model is CRX ED9... i can't seem to find much information on thsi model code..
Old 09-14-2015, 05:27 PM
mikesphat's Avatar
sounds like a junkyard is in your future
Old 09-14-2015, 06:02 PM
hspeck's Avatar
I wished my junkyard has chopped civic/crx...
i am from singapore and our cars are chopped or exported when they are 10 years old.. i reckon we only have less than 10 units of the 2nd gen CRX left in our country now ..
ours is not a friendly country for old cars
Old 09-14-2015, 06:09 PM
mikesphat's Avatar
i might be going to my junkyard this weekend...
ill see if i can find one if you pay shipping from usa
Old 09-14-2015, 06:16 PM
hspeck's Avatar
Appreciate if you can do that!
Thanks!
Old 09-16-2015, 01:44 PM
nikitad's Avatar
There is also a possibility that your IACV is not bad.
Weird idle can be caused by vacuum leaks, and IACV code can be also set off by a broken IACV wire.
Another IACV that would be compatible with yours is some of the B16 / GSR IACV's. With those you just need to make sure that bolt hole spacing is the same as yours. If bolt holes line up, everything else will too, and it will work in your car the same.
Source: Years of experience.
Old 09-16-2015, 01:49 PM
Tyson's Avatar
Old 09-16-2015, 05:11 PM
hspeck's Avatar
Thanks nikitad.
We have checked and there was no apparent vacuum leak. I will check the wires next.
Cheers!
RTFM
v4lu3s's Avatar
or if you wanted a new one you could just go to the parts store.
Old 09-16-2015, 05:14 PM
hspeck's Avatar
unfortunately it is no longer available to purchase new... or at least that was what the various places i checked told me....
Old 09-16-2015, 07:14 PM
RTFM
v4lu3s's Avatar
interesting since i fond it on my first try on autozone, oreilly, advance auto and rockauto. BWD, Duralast, Carquest, Ultra Power, Airtex and Standard Motor Products all make NEW idle air control valves.
Also checked NAPA they ahve Echlin branded iacvs.
If you are not in the United States you should probably indicate that since the vast majority of people on here are.
Old 09-17-2015, 12:25 AM
hspeck's Avatar
sorry, my bad...
but thanks for the tip!
I found it in rockauto! I have dealt with them before for my Nissan Skyline R32.
I started this thread cos I needed to know the OEM manufacturer's part number, eg Standard Motor's, Airtex , Duralast etc..
Thanks again!
91GEDHATCH
07-15-2014 06:05 AM
zdelure
08-08-2011 08:07 AM
classciv
05-31-2005 07:41 PM
daigo
02-08-2005 07:19 PM
nuc79
06-02-2003 03:19 AM
Quick Reply: IACV for ZC
