Koni yellow problems...
I bought some lowering springs that were (2.25 F, 2.0 R) and with my yellows perches at the lowest they would go, sat higher in the rear and the same in the front as my other crx (which has HP blues and Eibach sportlines (1.8 F, 1.7 R). So I bought a different set of springs (third set), "K Sport" (which are 2.5 F, 2.25 R) just swapped the rears out and its sitting a little higher!? WTH is going on?
oh ya and my crx with hp blues has 15 inch rims and 55 side wall and the one im trying to lower more has 15 inch with 50 side wall... still getting a good size gap in the rear and all this is pissing me off.. any ideas?
Re: Koni yellow problems...
My perches are like the ones in the pic.. and with all my perches as low as they can go, 2.5 drop in the Front and 2.25 in the Rear, 15 inch wheels with 195/50/15's, I still have a gap of like 1 3/4 in the rear.. havent installed the fronts yet but I think the fronts will be pretty low and just fine. maybe too low lol but its just that the rears are still sitting up there and idk why.
Did you forget to unset the E brake and let it roll before freaking out? It happens.... Lol
If you really want to drop the car lower, cut the top coil off.
heheheh ^^^^^ umm just make sure the perches them selves are set right and did you move the ring on the back to drop the height on the shock it self or just put the perches on ???
weakGOODJunKieS.com
04-05-2003 10:05 PM
