How to set ignition timing
Hey guys,
I noticed there is no how to to setup ignition timing so I thought I could at least get one started because I've been having major problems and think I've finally found out how to do it First off, set your mechanical timing line up the vee notch and pointer with the white mark on your crank pulley and line up your cam gear correctly Now the ignition timing Tools; 12 mm small piece of 20 gauge wire w/ both ends stripped Timing light Steps: The car must be warm Under the passenger kick panel theres a little clip that looks like something needs to plug into it, plug your wire into this to complete the circuit Now connect your timing light. It should have three leads one is for battery + one for battery - and one clip for spark plug wire number one, I put this one near the distributor end With the car running point the light at your crank pulley. You have to line up the vee notch and pointer with one of two marks on the crank pulley Here's the confusing part, on the hood label, my crx si reads 18 btdc What this means is that my timing light, set at 18 will line up with the white mark Set at 0 it will line up with the red mark If your car is off loosen the distributor and slide it around till you manage to line up the marks. tighten the distributor unplug the wire remove timing light DONE PLease post feedback Thanks for reading |
Re: How to set ignition timing
Pics of said little clip would probably help those that have never seen it before.
When looking at the crank pulley there's three lines, the middle being 16 degrees and the other two on the sides are +/- 2 degree's. If you're car is having idling problems are runs funny, setting the ignition timing is gonna be tricky.
88-89 crx "clip" have a different location.
they are located in the engine bay. right side of engine bay. has yellow cap. 90-91 "clip" is located to where you said. |
I am sorry but there is Soo much misinformation this should just be deleted. The reason there isn't very many "How TO's" is because people either use their manuals or know how to do it. If I get the time I will make one, because this one disturbs me deeply.
I made this hoping someone will make one
Google came up with too many different answers edit I have a 60 buck craftsman light I set it to 18 and line up the white line. If I try to line up the red line, my dizzy won't reach it My friend has a snap on one He set it to 18 and lines up the red line. Both were pretty dead on craftsman 60 buck snap on 300 bucks |
Originally Posted by 90civic-ZC
(Post 46668524)
nm found this post by tippyman They should look like this: ||| | The three lines together are your timing marks, the one by itself is the TDC mark. To get the timing right at factory specs, use the line in the middle of the three lines. however, does anyone have a pic of this plug under passenger kick panel that needs to be jumped? nm found that too, you guys are awesome,lol https://honda-tech.com/forums/showth...=timing+jumper |
Advanced timing is further from TDC mark and retard is closer towards TDC mark.
hi guys
i have a 1997 honda ballard which mark do i use as there is no colors on the pulley and the timing keeps going off / no power and car tends to heat a bit |
88-89 Service Check Connector
https://www.superhonda.com/photopost...econnector.jpg 90-91 Service Check Connector (by passengers kick panel) https://repairguide.autozone.com/zne...5280061658.gif Oh, and 5-seconds of googling finds this image straight from the Honda service manual: https://i38.photobucket.com/albums/e...crx/timing.jpg |
Hi 94eg
thank you ufortunally my wording was not correct on google as im not a mac therfore i did not get the correct images |
