How to install Ground Controls with Koni Yellows in a 88-91 CRX
Well here is my update that is going to double as a how to on the installation and building of Koni Sports (Yellows) and Ground Controls with and without aftermarket top hats...
This is my first attempt at a write up and I am doing it because these things do NOT come with directions lol. ***Koni Sport Yellows and Ground Control Installation write up for 88-91 CRX*** Step 1 - Get all of your parts together from all of the different boxes and have them readily available for the install. Step 2 - Remove old shock and strut and spring assembly from the car. You will need the top hats if you didnt buy new ones. Step 3 - Look at your ground control sleeves. One is taller than the other. The tall ones goes on the rear end of the car. The short ones go on the front... https://i744.photobucket.com/albums/...294067_n-1.jpg Step 4 - Grab the front shock. It is the one that is just round at the bottom. Lay out all of the things you will need. Like this. You need the springs as well I didnt have it in the picture. https://i744.photobucket.com/albums/...155414_n-1.jpg Step 5 - Grab the shock and install the plastic washer. It just pushes on. This shock. https://i744.photobucket.com/albums/...754709_n-1.jpg This washer. https://i744.photobucket.com/albums/...399411_n-1.jpg Installed. https://i744.photobucket.com/albums/...733355_n-1.jpg Step 6 - Grab the short ground control sleeve and slide it on. https://i744.photobucket.com/albums/...ps42e36001.jpg https://i744.photobucket.com/albums/...psd25a5c0b.jpg Step 7 - Find the bump stop and grab it and put it on. https://i744.photobucket.com/albums/...ps8d4eb2ec.jpg https://i744.photobucket.com/albums/...ps7d0781b4.jpg Step 8 - Find the washer and the metal sleeve put them on. The washer goes on first. These came with your Konis... https://i744.photobucket.com/albums/...ps69411a0c.jpg https://i744.photobucket.com/albums/...ps09732108.jpg https://i744.photobucket.com/albums/...ps36555807.jpg This is what you have so far. https://i744.photobucket.com/albums/...ps6b6af2a7.jpg Step 9 - Grab whatever spring you are putting on the front. I am just running the recomended from Ground Control off the shelf rate for the front at 350. https://i744.photobucket.com/albums/...ps21e36b81.jpg Step 10 - Find your top hat. - This is where things change if you bought aftermarket extended ones. If you are using the stock top hat remove it from the old front spring and shock assembly. Inspect the rubber bushings on it to make sure they are alright too. Stock Top Hat https://i744.photobucket.com/albums/...ps6a17fd96.jpg Step 10a - This is for you guys with new extended top hats. Take your extended top hat out and install the included bushing into the top. https://i744.photobucket.com/albums/...psaae9ff37.jpg https://i744.photobucket.com/albums/...ps7ca4f680.jpg https://i744.photobucket.com/albums/...psf6428840.jpg Step 10b - Install a second bushing into the bottom of the top hat. The smaller side goes down. So it should look like an upside down ice cream cone. https://i744.photobucket.com/albums/...pse47cc53a.jpg Step 11 - Put the top hat on! https://i744.photobucket.com/albums/...psbdd6b09a.jpg Step 11a - if you have the extended top hats put the new rubber piece from GC on so it fits your top hat. https://i744.photobucket.com/albums/...ps0223a16c.jpg https://i744.photobucket.com/albums/...854169_n-1.jpg https://i744.photobucket.com/albums/...psd1f5ae3d.jpg Step 12 - Find this and install it facing up so it makes a bowl. https://i744.photobucket.com/albums/...psfabae5da.jpg Step 13 - Add these two nuts on one at a time! The second will lock them in place. https://i744.photobucket.com/albums/...ps6cbeec2f.jpg https://i744.photobucket.com/albums/...815811_n-1.jpg https://i744.photobucket.com/albums/...815811_n-1.jpg Step 14 - Double check they look like this. https://i744.photobucket.com/albums/...ps4aa2a974.jpg Repeat the process using the rear shocks now, but use these pieces instead. Rear shocks look like this. https://i744.photobucket.com/albums/...ps5a82e840.jpg Use the taller ground control sleeve. This one. https://i744.photobucket.com/albums/...ps9a108588.jpg Use this spring instead. https://i744.photobucket.com/albums/...ps21e36b81.jpg annnnd you should end up with them looking like this! https://i744.photobucket.com/albums/...psebb0983c.jpg https://i744.photobucket.com/albums/...ps69803f79.jpg https://i744.photobucket.com/albums/...ps8435d93e.jpg https://i744.photobucket.com/albums/...pse51eadf6.jpg PM me if you have questions... Very Low :) http://i744.photobucket.com/albums/x...136851_n-1.jpg http://i744.photobucket.com/albums/x...425819_n-1.jpg http://i744.photobucket.com/albums/x...177742_n-1.jpg http://i744.photobucket.com/albums/x...401115_n-1.jpg http://i744.photobucket.com/albums/x...165313_n-1.jpg Setup to drive... http://i744.photobucket.com/albums/x...318288_n-1.jpg http://i744.photobucket.com/albums/x...515630_n-1.jpg http://i744.photobucket.com/albums/x...541959_n-1.jpg http://i744.photobucket.com/albums/x...966401_n-1.jpg Final shots! After driving a few hundred miles and letting them settle... Dont mind the color change haha... https://i744.photobucket.com/albums/...ps7bc497f9.jpg https://i744.photobucket.com/albums/...ps2e71c623.jpg https://i744.photobucket.com/albums/...psc71965cc.jpg |
Re: How to install Ground Controls with Koni Yellows in a 88-91 CRX
I did the koni's and GC's but when I did mine someone put coilovers on it before I did
So a lot of my stuff was missing My question is what goes in between the spring and top hat on the front? Mine squeaks for some reason |
Originally Posted by mike205
(Post 48608098)
So a lot of my stuff was missing My question is what goes in between the spring and top hat on the front? Mine squeaks for some reason The round black thing. Upper spring perch insulator. You can order oem for $15 each, or like $5 each aftermarket (MOOG). |
Originally Posted by F22Master
(Post 48608201)
Step 11a
(Post 48608201)
Step 11a
The round black thing. Upper spring perch insulator. You can order oem for $15 each, or like $5 each aftermarket (MOOG). http://www.koni-na.com/pdf/1150-5006-1.pdf The Ground Control instructions for '92-'00 Civic/Del Sol and '94-'01 Integra have a note that says "Remove Stock Upper Spring Perch". i called Ground Control and they confirmed that the note refers to the rubber spring perch insulator. But it might be worth it to use the insulator to quiet things down for a slight loss of performance. |
Thanks
What the name of the bushing in pic 11a?
Thanks |
I think I might of figured it out is this correct?
Front Coil Spring Isolators |
You are an absolute legend for posting this, I have been trying to just figure out how to do this exact setup, and 2 hours later, I find this post and realize I'm missing my bump stops and was going to put it together without the plastic washer and added the bottom spring perch when I didn't need to. THANKS SO MUCH FOR TALING THE TIME TO WRITE THIS UP AND KEEPING THE PICS ACTIVE!!
