How to fix a FITV its as easy as 1, 2, 3....
#226
my setup: D16y7
ok so ive read up mos of this stuff.... but heres my problem. the car is cold.. i start it up the engine revs upto 1200rpm once it warms up completely the engine revs upto 1600rpm.... so once the car was warmed up i took off the intake and covered up the bottom hole (the FITV) and the car shut off! now supposevely the the FITV shouldnt be sucking any air after the car is warmed up so im ??? i took out the IACV and cleaned the screen put back on and the same thing... what should i do??
#227
Re: How to fix a FITV its as easy as 1, 2, 3....
This thread is useless without pictures.
air can leak past the gap
closed down and sealed
FITV disassembled
My FITV Block Off Plate
FITV disassembled
#228
they are also on the f22a6 motor from the 90-93 accord ex-r, i know because i had a bitch of a time working on that motor and the FITV had to be re-tightened. If you have one of these, I HIGHLY recomend tightening it. The OP is not kidding when he says it makes a HUGE difference.
uNF$@#!
09-20-2003 10:58 AM
