which axles for hydro transmission
I've been searching forever but cant find a straight answer. Will my stock axles (STD hatch) work with a 97 hydro transmission?
Thanks
Thanks
Re: which axles for hydro transmission
dohc and sohc are different of course.. u gotta use the same axles and halfshaft. if u got a cable b16 motor and trans and then switch to hydro trans u use same axles and halfshaft. hope that helped
sorry should've been more specific. I'm staying d series just swapping transsmissions.
I agree.
The only difference between axles between a 92-99 civic ex and a 88-91 Si, is that the Si will have a thicker shaft, but the splines and shaft that goes into the transmission and hub are the same.
The 88-91 axles are different lengths than 92-95.
EG Left = 773mm-778mm
EG Right = 500mm-505mm
EF Left = 775mm-780mm
EF Right = 483mm-487mm
lilsicsoul
03-18-2009 04:56 AM
