Fed up with PWJDM and SwapShopRacing, so I made my own
Old 04-20-2018, 09:44 AM
Canadian_EF's Avatar
Default Fed up with PWJDM and SwapShopRacing, so I made my own
I have been trying to purchase a PWJDM battery box for well over a year from PWJDM and SwapShopRacing and have finally given up completely. Every month they tell me "They'll be ready next month" and that "We're having problems with our supplier"
I finally got fed up and made due with cheaper parts and a bit of work.
I used a piece of 3/16" steel, 3"x9" purchased for a whopping $2 CAD
I bought a battery box from Portable Power, $17.50 + $35 shipping USD. You can buy it here: https://www.portablepower.com/produc...ttery-box-unf/
Some bolts, washers, a drill press, welder, and a diamond hole saw that I had left over from a tile project.
The idea is, make a template from cardboard, and cut the holes as required... The bracket mounts via two holes to existing frame rail bolts. I'll post up some more pics when I get it powdercoated to hide my awful welding skills. It is very sturdy.
Drill 4 holes to bolt the plate to the bracket.
Top right hole (if the battery is sitting straight up and down) will bolt to the frame. Washers are welded behind it to space it away from the frame.
The other hole is roughly 3/4" from the top of the plate. I used a piece of cardboard to figure out where this will be located.
You don't need a hole saw. You can cut a really big hole (enough so a socket on a bolt can fit in the hole) and weld big fender washers or something to the back of the plate, and then drill the hole... Lots of ways to make it. It is a super simple design.
I cut the bottom left corner of the battery box to clear my traction bar bolts.
Just wanted to show that a functional piece can be made for way under $100... This isn't really intended to be a how-to.
I am fed up with PWJDM. This is the only product I ever wanted from them, and well, now I have no reason to ever buy it from them.
Old 04-22-2018, 04:03 PM
EFB055
~sp33~'s Avatar
Default Re: Fed up with PWJDM and SwapShopRacing, so I made my own
Nice work, doing something for yourself.
Old 04-23-2018, 08:28 AM
After powdercoating
Here you can see how the one bolt is counter-sunk into the plate. I attach the plate to the frame with this one bolt first.
Here's the awful welds you'll never see. (Except right now)
***Edited to change image host to imgur
Old 04-25-2018, 02:42 AM
GonzoWerke's Avatar
Built, not bought, is best.
Old 04-26-2018, 07:53 AM
PHANTOM MENACE
24TEN's Avatar
Pics are blocked at my work but I'll say good job on the DIY aspect.
Old 05-01-2018, 11:40 AM
My welds are too dirty for your firewall
Canadian_EF
03-26-2018 09:04 AM
ef9robert
11-11-2008 09:54 PM
coot_er
17
05-28-2007 06:23 PM
AaronJ
07-25-2006 04:14 PM
turbotommy
37
08-09-2004 09:40 PM
Quick Reply: Fed up with PWJDM and SwapShopRacing, so I made my own
