FAQ: How-to on removing steering rack(non-power steering) - Page 2 - Honda-Tech - Honda Forum Discussion
Old 09-13-2003, 10:01 PM
  #26
Hcivic88's Avatar
Default Re: How-to on removing steering rack(non-power steering) (raene)
another thought.. if the crossmember you're taking it off of is done anyways, just take the grinder and cutting wheel to it and cut the rack out you'd only have to make 4 cuts, lol.
Hcivic88 is offline
Old 09-13-2003, 10:22 PM
  #27
raene's Avatar
Default Re: How-to on removing steering rack(non-power steering) (Hcivic88)
heh, yeah, I've seriously considered it But I don't want to cut the good crossmember when I'm trying to swap it into my car so I'd rather learn how to do it w/o cutting
raene is offline
Old 09-14-2003, 11:41 AM
  #28
Aragorn's Avatar
All I remember is I had to put the rack full lock to one of the sides and then I had the clearance needed.
Aragorn is offline
Old 09-14-2003, 12:25 PM
  #29
4crx4me's Avatar
Default Re: How-to on removing steering rack(non-power steering) (Aragorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aragorn &raquo;</TD></TR><TR><TD CLASS="quote">All I remember is I had to put the rack full lock to one of the sides and then I had the clearance needed.</TD></TR></TABLE>
Yes, I forgot. That helps too.
4crx4me is offline
Old 09-14-2003, 01:37 PM
  #30
mugensport9's Avatar
hey man your website has some great info for the d16z6-ef swap.
one question. when swaping the d16z6 do u need a converson mount or anything to use the hydro tranny?
mugensport9 is offline
Old 09-14-2003, 05:51 PM
  #31
raene's Avatar
Default Re: How-to on removing steering rack(non-power steering) (4crx4me)
Good idea, I'll try that!
raene is offline
Old 09-15-2003, 11:04 AM
  #32
Malgerus's Avatar
Default Re: (mugensport9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">hey man your website has some great info for the d16z6-ef swap.
one question. when swaping the d16z6 do u need a converson mount or anything to use the hydro tranny?</TD></TR></TABLE>
You'll want to reuse your cable d series tranny. If you have a DX or STD tranny, consider picking up an Si transmission. I don't know of any adapter kits that allow you to use a hydro tranny in a cable application for the D series.
Modified by Mr. S at 12:18 PM 4/12/2004
Malgerus is offline
Old 09-28-2003, 05:54 PM
  #33
jaydm98's Avatar
How long did it take you to remove and install the rack?
jaydm98 is offline
Old 09-28-2003, 07:01 PM
  #34
Hcivic88's Avatar
Default Re: How-to on removing steering rack(non-power steering) (slopokb16crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slopokb16crx &raquo;</TD></TR><TR><TD CLASS="quote">How long did it take you to remove and install the rack?</TD></TR></TABLE>
umm... i dont remember exactly
im guessing somewhere between 40mins and an hour.
could have done it a lot faster if i had a hoist or something, instead of laying under it.
Hcivic88 is offline
Old 09-30-2003, 01:24 PM
  #35
jaydm98's Avatar
Yeah, i just got done putting my steering rack and pinion yesterday. Took about 1 hour.The ride feels much better and it feels smoother.
jaydm98 is offline
Old 09-30-2003, 01:36 PM
  #36
raene's Avatar
DANG you guys are good! Did you remove the exhaust & shift linkage, or just work around it?
raene is offline
Old 09-30-2003, 02:07 PM
  #37
jaydm98's Avatar
Yeah, we took off the exhaust, the mid pipe.Just unbolted the cat to header bolts, and hangers on the resonator. Moved the rack as for to the right then lower it, worked around the shift linkage, and lowered the rack, looked like the shift linkage would be in the way, worked around the shift linkage didn't have to take it off at all.I guess because i have a swap b16a first gen with hcp mounts and a hasport shift linkage,the motor sits lower.But a steering rack is a good investment.Hope everything works with yours.
jaydm98 is offline
Old 09-30-2003, 03:36 PM
  #38
Hcivic88's Avatar
I took off my shift linkage. I dont see why everyone has so much trouble witht he "bitch pin". I live in canada, so I get a lot of rust and anything, but I never seem to have any trouble getting it out. and I just unbolted my cat, front and back, and that got the exhaust out of the way.
Hcivic88 is offline
Old 09-30-2003, 04:03 PM
  #39
raene's Avatar
Well the F-ing muffler shop welded my cat bolts to my exhaust manifold so I guess I won't be changing my rack anytime soon.
raene is offline
Old 10-03-2003, 04:17 PM
  #40
jaydm98's Avatar
Hey did you get a wheel alignement after you replaced your steering rack and pinion?
jaydm98 is offline
Old 10-03-2003, 04:27 PM
  #41
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slopokb16crx &raquo;</TD></TR><TR><TD CLASS="quote">Hey did you get a wheel alignement after you replaced your steering rack and pinion?</TD></TR></TABLE>
I DID, and NEW yoko ES100's.
OMG!! What a DIFFERENCE. NEW rack, tie rods, tires + a good alignment makes = .
It's really like driving a brand NEW car!! My CRX is FUN to drive again.
4crx4me is offline
Old 10-03-2003, 05:03 PM
  #42
jaydm98's Avatar
Yeah the only thing i have to do is to get my wheel alignement.
jaydm98 is offline
Old 10-05-2003, 11:53 AM
  #43
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slopokb16crx &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the only thing i have to do is to get my wheel alignement.</TD></TR></TABLE>
Well guys I got the rack dropped last night... didn't even have to remove the shift linkage or the exhaust. I just worked around them. So I now have a Civic DX rack, new tie-rod ends, extended wheelstuds and new wheel hub bearings... if I could get an alignment done today I'd let you know how it drives too Tomorrow!
raene is offline
Old 10-05-2003, 05:31 PM
  #44
Hcivic88's Avatar
yup, I did. didnt get new tire tho, since they arent very old at all, still pretty much band new, only had them for a month or two of driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Well guys I got the rack dropped last night... didn't even have to remove the shift linkage or the exhaust. I just worked around them. So I now have a Civic DX rack, new tie-rod ends, extended wheelstuds and new wheel hub bearings... if I could get an alignment done today I'd let you know how it drives too Tomorrow!</TD></TR></TABLE>
finally, lol, j/k man.
let us know how it is after the alignments done, should feel like a whole new car with the new rack, mine sure did.
Hcivic88 is offline
Old 10-15-2003, 09:16 AM
  #45
raene's Avatar
Well, alignment, new tie rod ends, new wheel hub bearings, and the new rack... and it drives GREAT I had it at autocross and while all the new parts didn't make a huge difference in overall handling it helped out with the responsiveness quite a bit. Less flailing behind the wheel, you could say
raene is offline
Old 01-30-2006, 09:13 AM
  #46
charlie_sohc's Avatar
Default Re: How-to on removing steering rack(non-power steering) (CRXRageD)
what part store did you buy it from........i work at one and the only on they could get is the power sterring one..........and dealer wants 500 for it......lmk
charlie_sohc is offline
Old 01-30-2006, 09:26 AM
  #47
cbp_crx's Avatar
Default Re: How-to on removing steering rack(non-power steering) (charlie_sohc)
very nice, i will be doing this probably next week, i think ill be using this thread for instructions
cbp_crx is offline
Old 06-05-2017, 03:42 PM
  #48
hey mate any help on removing the rack I'm having the same trouble not being able to remove the rod going through the x member
have removed 4 bolts on the rack
fluid lines
exhaust
shifter linkage
outer tie rods
Phill Hill is offline
Old 06-05-2017, 04:07 PM
  #49
Keyboard Humorist
4drEF's Avatar
Default Re: FAQ: How-to on removing steering rack(non-power steering)
Time machine required to access reply to post.
Last activity - 2006.
4drEF is offline
Tyson
10
08-17-2018 12:16 PM
zorobabel
07-22-2017 03:04 PM
EFing_Slow
06-04-2017 02:10 PM
kyosoeg6
30
11-11-2016 07:10 AM
h22a2JZGTE
05-26-2016 11:36 AM
Quick Reply: FAQ: How-to on removing steering rack(non-power steering)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
