Battery drain overnight. Load located in the hazard circuit.
Old 06-05-2017, 03:02 PM
Elderly Iron's Avatar
Default Battery drain overnight. Load located in the hazard circuit.
1990 Civic LX.
Using a test light from battery positive post to battery positive terminal, I have a bright light whenever the Hazard circuit fuse is installed. With the hazard switch in the ON position, the light is steady. With the hazard switch in the OFF position, the light will flicker at a pace equal to the hazard flash tempo.
Having searched a bit, I find there is an ICU, which does not appear in any wiring diagrams I can find on the web. Does anyone know, or has heard of a battery drain due to a faulty ICU?
Old 06-05-2017, 04:19 PM
Tyson's Avatar
Default Re: Battery drain overnight. Load located in the hazard circuit.
check if your tail lights and brake lights are working. try removing the bulbs individually, see if the shorts persists.
R_A_Y_N_E
04-04-2014 04:06 PM
civicsaremean
07-17-2007 11:35 PM
Mr.Speed
12-08-2006 11:43 AM
Mexan02
07-23-2006 07:36 PM
ceLtic
06-11-2004 06:50 PM
Quick Reply: Battery drain overnight. Load located in the hazard circuit.
