FAQ: D15 OBD1 SOHC VTEC Mini-Me : Massive Write-up (56k No Way)
#52
Re: (00CivicGirl)
depends on what tranny you have in there now. if you have a dx-cx-lx transmission you're gonna benefit with the ex/ si tranny. you can send me an IM if you have IM and let me know what tranny you're using now.
#58
Power Steering Pump Does not line up
Thanks for the mad write up about building a Mini Me. I just done my own Mini Me for my 95 Civic Sedan. I had a D16Z6 from a donor car that was in a accident. That ran well for about 4-5 Years. Then I spuna bearing on the D16Z6. In the mean time, I had to buy my brother a engine for his 90 civic sedan (D15B2). So I decided to build a Mini Me instead of buying another D16Z6. Long story short. Built it, dropped it in, and now I have this problem with the power steering pump not lining up with the crank. I have it off right now so it wont leak anymore. And whenever I have the car running for awhile, it turns on the oil light. If anyone got any ideas on these two problems, please let me know. I love my power steering, since it is in there and would like to continue to use it. There was a bunch of other things I ran into while putting the engine in the car. But I got around it. Mahalo!
#59
Re: Power Steering Pump Does not line up (808minime)
Sorry to bring this thread back from the dead I was searching the FAQ section, and I want to eventually do the mini-me swap on my DD CRX, but it has an automatic tranny which I want to keep.
Has anybody done the mini-me swap on an auto, and is it worth it powerwise?
#60
It will work just the same, the tranny is seperate from the engine. But you'll have difficulty finding an Auto ECU that will control VTEC. I dunno if there even is one...
#61
Re: D15 OBD1 SOHC VTEC Mini-Me : Massive Write-up (BauleyCivic)
Hey everyone, i'm a n4wb to the forum here, so I can't IM anyone or else I would.
What I have:
-1989 Civic HB 5-speed MTX that needs to pass safety.
-I work part time in an engine rebuilding shop that my uncle runs but doesn't own.
-An income of $150-200/week of which I can dedicate at least 1/2 to my car.
-The ability to get help from my uncle and my buddy to help me with my mini-me swap.
-The ability to use the shop I work at for a place to do the swap, and at the same time having every tool I need to get the job done.
What I'm having problems with:
-The fact that my insuance company says that my car is a 1.6L but under my hood it clearly says 1.5L.
-Figuring out what engine is in my car (D15b1 or D15b2)
-Not knowing much about the car itself.
-Not knowing some of the abbreviations used in the forums.
-Pretty much anything to do w/ electrical...i'm slightly nervous of how difficult it will
be to get vtec working once I do my swap.
Plans(oh finally the good stuff):
-Get the car safety passed (easy, hopefully soon)
-Do some body work (easy, whenever I have time)
-Random odds and ends for interior. (Pick n' Pull this weekend is 50% off)
-Swap my current head w/ a D16Z6 head.
So i've really only been studying into this mod for a couple days but i'm pumped to do it. Really i'm not too worried about budget...I just want to keep it under $1000 but at the same time, the cheaper, the faster it will get done. I'm worried about compatability though.
N4wb Questions:
**How do I know if my engine is a D15b1 or a D15b2...?
**will a P28 ECU be compatable for my application? Where is the ECU located?
-OBD...stands for what, and do I need to be concerned about it?
-Dizzy... means?
-D16Z6 Timing belt works for my application, correct?
-Is there anything that I should know about when it comes time for the swap, that has to do with compatability diffrences between my 89 civic and the one discribed in the guide?
What I have:
N4wb Questions:
-Dizzy... means?
#64
I have a minime setup right now not presently in my crx, it's a b7 on a d16z6 head similar to yours. I was wondering... is there a site where they sell obd0 to obd1 harness?
#65
Just to help you out virtuoso to answer your questions
1. You should be able to find out if its a b1 or b2 by simply looking at the engine below where the head is more toward the left you'll see an engine code... it'll tell you right there.
2. p28 ecu is compatible
3. Dizzy is distributor
4. That is the most prefered timing belt for your applicaton
5. You'll need an obd0 to obd1 harness, obd1 distributor, that's what I know for now
#66
Re: (hassibi)
okay question because now i am confused....i know that this is a b7 w/a z6 head mini-me thread but, i am wanting a little more info on a 90 honda civic std. d15b1 mini-me swap...
i have been reading and reading and reading and searching on this matter. i want to use the z6 head but i am confused as to what i need to have in order to make this work....
this is what i would like to do....
please do tell me what will work and what won't work..
this is my first mini-me swap....
-d15b1 block
-full d16z6 head...intake manifold, fule rail, injectors (dizzy??? what kind???)
-new arp head studs...
-all new gaskets...(head gastket, throttle body gasket, intake manifold gasket...)
-wiring harness----what kind of wiring harness??? do i use my stock harness???
i know i will need the resitor box, that's about it....i'm not too sure how to wire up vtec or the other injectors but, am still reading up a little closer on that...shouldn't be a prob though..
-p28 ecu
-z6 timing belt????
-z6 water pump???
am i missing anything?
and again if i have any thing wrong please help me out. i wanna do this right and am just not too sure!!!
any insight is much appreciated!!!
THANKS
-d15b1 block
-p28 ecu
-z6 timing belt????
-z6 water pump???
THANKS
#67
i got a problem with my mini me swap... help is needed... ok i have completed the swap but some my rev is limited to 5500... wonder why it's like that??? could the oil jet be the problem to it...
#69
Re: FAQ: D15 OBD1 SOHC VTEC Mini-Me : Massive Write-up (56k No Way)
I have an important question!! If i have a Civic VX?is there any other way for me to change the pistons dish???
i have already bought the main parts for this swap
#70
is there any way this can be updated with new pictures? The old ones have been gone awhile and they could help a bit
#71
Hey everyone. So im a huge honda fan (in the making). just bought my first honda. Dont know much about the motors but im learning quickly. I was disapointed when i found out how weak the d15b1 is so i decided to do a mini me swap. After reading this write up everything seems pretty simple. My only question is. can i use my harness? or will i need to get a new one for the d16z6 head and intake mani?
Sorry if someone already asked that.
#72
So I'm new to the site but I saw you awesome write up. It's awesome that you have enough passion to write it all out for everyone else. I do have some questions though. I have a 92 eg with a d15b7. I just picked up a d16y8 head and I'm planning on doing the swap here shortly. What do I have to do to keep it obd1? Which dizzy and ecu would be the best fit for me with this swap? Also will the injectors from my b7 work with the y8 head and fuel rail?
#73
i have a d15b8... can i do a mini me swap and use a d16y8 head .... if so are the instructions the same as u have stated before
#75
Have a quick question, my z6 blew up yesterday and i have a d15b2 block and i am going to do a mini me.... My buddy told me to do a vx timing belt is this correct?
Thanks for any imediate help.
Steven
Steven
