ef z6 no fuel no spark help
i recently swaped a new motor into my ed6 AGAIN this time i downgraded but w,e,also it was a dx i runed civic 4door ex underdash harness with a si engine harness everything plugs up but i see that some plugs are missing i guess is for the power windows and locks also i cut the boc that i guess makes the sound of the ignition when u open it so that is no longer conected idk if that matters ! the reason im coming here is cause the check engine DONT light up when i turn on the ignition i hear the main fuel relay click twice but the fuelpump dont go on i runed a extra wire and it does turn on the fuel pump but i dont want to run it like that, and also is getting no spark i checked if the distributor was getting power and it was ! idk what coulkd it be plz i know that a couple of ef owners runed to this problems before help me porfavor :ugh:
Re: ef z6 no fuel no spark help
bump hellp plz
What year is the cluster and the dash harness you used? 88-89 and 90-91 are different and need a couple wires swapped. What engine harness are you using?
well i bought the cluster and dash from a ed9 crx and the underharness is from a 90 4door ex the car when i take out the ecu the main relay click once i put the ecu bak and it clicks twice bu no engine light or anything comes on i checked all the grounds and i tink all of them re fine what else could it be give me answers guys plz
no spark no fuel at all
bump bump plz help
