ef w/ls engine b16 trans???
I have a ls in my ef and the guy I got it from had a hydro axle for the passenger side and it is too long to go in my tranny. I was wondering what I should get the axle from to make it work correctly. It also seems like the splines are too small on the hydro axle because it seems loose. LMK?
1 Post
Re: ef w/ls engine b16 trans???
hydro and cable both share the same pass side axle. the only difference is the abs ring but that fits too. even the automatic axles fit. you have some other problem or thats not an integra axle
I know for sure that the axles are integra cause I had one that I pulled from a 96 gsr trans. but the axle seems long and loose both of them.
well not many people on here know there asses from a hole in the ground sorry.
but anyways I took the axle that i had off my 94 civic with a gsr in it for reference to the local parts store and had them look up a 92 integra rs ls and gsr and 94 the same way and they all showed the same axle so i had the guy get it and it was totally different from the one i had. So now it works....
