ef hatch issues help!!
ok guys i got a 91 dx hatch and im having a few issues. first off the gas and temp part of the cluster dont work but everything is hooked up. guy i got it from says maybe it dont work because the cluster is from an 89 and the hatch is a 91 but i dont think there is a difference is there?? also my other issue is i have no turn signals. the switch on the column is hooked up and hazard switch is hooked up the turn signal fuse is good and the hazards even work just when i hit the turn signals they dont come on not even on the cluster but they work on the car and cluster when i hit the hazards. can someone please help me
Re: ef hatch issues help!!
You need a cluster out of a 90 -91 that might fix your gauge problem as long as everything else works.......and don't quote me but I think I went through that turn signal deal myself once and it was because I had a 89 cluster in my 90. I'd start with getting a 90 - 91 cluster and then go from there.
What do the cluster plugs look like? I put a 91 si cluster in with 88-89 harness. They are different. There are 4 wires that need to be switched, which made my cluster work.
check this and make sure they are correct. http://crxcommunity.com/viewtopic.php?t=6184
The fuse for the hazard lights is under the hood on the passenger fender. I believe its the first fuse closest to the outside of the fender..
