Driver side flooring wet
i haven’t drove me crx all day yesterday and when I got into it today I realized my driver side is so wet. I have my parked backwards in my driveway and it uphill. So I’m trying to figure out where is this water coming from? Has anybody ever dealt with this problem?
Re: Driver side flooring wet
i assume from your user name you have an Si with a sunroof...
https://honda-tech.com/forums/honda-...tubes-2861131/
there are also drain tubes up front. exit is near the main relay/hood release.
could be a leak from the sunroof...could be the heater core leaking...check your radiator to see if you lost any coolant, that would indicate a possible heater core leak. as far as the sunroof, open it and pour water in the trap and see if it drains properly through the drainage tubes. if the tubes are blocked, that would cause a leak inside your vehicle as well
It’s probably the sunroof drains...happened to me .I used a shop vacuum and sucked everything out... just had a major rainthe past few days and the driver/ passenger flooring was dry...
give it a try
give it a try
ITR0529
12-29-2006 07:00 PM
