Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda CRX / EF Civic (1988 - 1991) (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/)
-   -   DOHC ZC code 1 (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/dohc-zc-code-1-a-2601895/)
RyanJayx Jul 5, 2009 06:09 PM
DOHC ZC code 1
My CEL comes on after about 3 minutes of driving and when it does, my car loses power. I have to turn the key off and then back on to reset it, and then it will go another 3 minutes before doing it again. The ECU is flashing a code 1 for 02 sensor. The only think I can think of is that I am running a PG7 instead of a PM7. Any ideas??
beana Jul 5, 2009 07:06 PM
Re: DOHC ZC code 1
code 1 is oxygen content, which is the o2 sensor, make sure it's plugged in, if it is change it
RyanJayx Jul 5, 2009 09:46 PM
Re: DOHC ZC code 1
I have changed it, twice and it didn't affect it at all. Could it be a vacuum problem?
~sp33~ Jul 6, 2009 01:10 AM
Re: DOHC ZC code 1
Yes. If your engine is running rich your O2 sensor will throw a code 1.
Check your vac lines to your map sensor.
northemt88 Jul 6, 2009 09:21 AM
Re: DOHC ZC code 1
i thought you don't need your o2?im not running one and not a problem every now and then i get the cell.its a stock ecu
~sp33~ Jul 6, 2009 09:44 AM
Re: DOHC ZC code 1
Honda just put it in there for fun.
northemt88 Jul 6, 2009 01:42 PM
Re: DOHC ZC code 1
lol
