D16Z6 with D16B2 power steering pump?
I put in a D16Z6 in my EF sedan. I have the power steering pump and lines for the D15B2 still connected, but the pulley for the B2 is a v-belt, where the crank pulley on the Z6 is a ribbed belt. Will a v-belt stay on and in place? or is there a different pulley I can put on the pump?
Re: D16Z6 with D16B2 power steering pump?
You have to re use your d15b2 crank pulley. trying to use the v belt on the ribbed pulley will make a TON of noise and will shred it quite quickly.
I read that swapping a B2 crank pulley onto a Z6 crank is bad for the bearings. Any truth to that?
i have a similar issue to this.
I cannot get the B2 bracket to bolt to the Z6 engine. Anyone have a z6 in an ef with power steering?
swap the pump pulleys, I've done alternators in the same fashion, I don't see why it wouldn't work on the power steering pump...
Keyboard Humorist
Anyway - I ran a B2 pulley on a Z6 for a long time. Had A/C, PS, and alternator with no issues.
interesting. just scared about killing the bearings.
Then the problem i have is using the B2 crank pulley, which from what i read, is terrible for the Z6 blocks bearings.
longlivekel1
19
04-06-2010 05:59 PM
civicdelsol33
08-23-2007 06:42 PM
