d16a6 (Si) motor electrical sensor questions
Old 06-04-2002, 05:29 AM
red civic standard's Avatar
Default d16a6 (Si) motor electrical sensor questions
If you are looking at the CRX SI motor from the BACK (staring at the intake manifold) there are four electrical sensors. Going from left to right I believe they are:
air temp sensor (left side of intake manifold), tandem valve control solenoid valve, electronic air control valve, then throttle position sensor (far right).
Is this correct?
Old 06-04-2002, 06:22 AM
lelopez's Avatar
Default Re: d16a6 (Si) motor electrical sensor questions (red civic standard)
I would have to agree with your assessment.
L.
Old 06-04-2002, 07:02 AM
Default Re: d16a6 (lelopez)
thanks lelopez. then I have a new question.
Doing a DX to Si DPFI to MPFI swap and there is no plug on the DX wiring harness that will plug into the SI tandem valve control solenoid valve. Is this sensor not necessary?
DA_Boy_626
10-03-2007 06:50 PM
lowered94accord
05-07-2007 09:24 PM
civic889802
12-30-2005 01:04 PM
sodacan33
04-26-2004 06:31 AM
ijjz
03-25-2004 08:28 PM
Quick Reply: d16a6 (Si) motor electrical sensor questions
