wire tuck set back.. high rev.. help!
Old 11-29-2010, 08:54 AM
CRXguy_88's Avatar
Default wire tuck set back.. high rev.. help!
Ok the car is done and everything is moved except the battery. When I start the car, right off the bat it just starts reving higher and higher.. it seems to stop at a point but when I rev with the gas it goes even higher and then goes back to where its reving itself. what in the hell could cause this? Anyone have a clue?
Old 11-29-2010, 09:37 AM
dudesitsjdm's Avatar
Default Re: wire tuck set back.. high rev.. help!
iacv?
Old 11-29-2010, 09:59 AM
90Rexx's Avatar
check your coolant level, and bleed your coolant system
Old 11-29-2010, 10:10 AM
CRXguy_88's Avatar
I did disconnect the hose that runs from the manifold to the iacv.. and prior to this happening I had that bouncing idle thing but I did change iacv's and cleaned it and after the tuck I get this now..
Old 11-29-2010, 10:14 AM
did you check all your vacuum line's?
Old 11-29-2010, 10:37 AM
Todhunter's Avatar
Unplug your IACV to see if it corrects the issue. Possible you wired it up incorrectly?
Old 11-29-2010, 10:45 AM
CRXguy_88's Avatar
Vacuum looks good to me but idk tried the pm7 ecu seemed to run really rough. Went back to my pm6 same thing.. idk man it revs so high instantly after starting it.
Old 11-29-2010, 10:48 AM
Todhunter's Avatar
Then you have a vacuum leak somewhere - IACV, brake booster, vacuum lines, intake manifold gasket, bent throttle plate, etc. You have a simple problem with a few potential causes - just methodically go through everything and find where the air is getting past the throttle plate un-metered. Your throttle cable isn't over tightened is it?
Old 11-29-2010, 10:51 AM
CRXguy_88's Avatar
The only wires I Cut and extended were headlights (high and low), corners, bumper lights, the two little wires that run to the brake booster, horn wires, radiator fan, extended the wire from the positive terminal to the fuse box. That's it pulled the fuse box and harness cluster on the pass side into the car tried to start it.
Old 11-29-2010, 11:04 AM
CRXguy_88's Avatar
Well I did disconnect the hose that goes to the brake booster to the back of the manifold and if made a sound like a lot of pressure was released after I heard the the I twisted the pipe coming from the mani downward w. Rubber hammer then ran the brake booster hose to it to hide that but before this it ran ok, throttle cable hasn't been messed with same as the intake mani gasket, it was fine too. My vacuum lines look good nothings left without a hose or unplugged. I also disconected the hose that runs from the intake manifold up to the iacv and souded like I released pressure too. -_-
Old 12-02-2010, 10:06 PM
CRXguy_88's Avatar
Anyone?.. Help?
honcrf150
13
05-29-2012 10:28 AM
lude98SH
10-29-2006 03:17 PM
ReGMiLLa31
Honda S2000
10-28-2006 07:28 PM
mdj_ge
07-18-2004 08:31 PM
FreshSol
08-25-2003 11:47 AM
Quick Reply: wire tuck set back.. high rev.. help!
