d16 block/d15b head help??
wanting to mini me my d16a6. will a jdm d15b head bolt right up? any wiring changes need done? a write up on this would be super helpful
Re: d16 block/d15b head help??
Your ability to search is pretty terrible then.
This is some stuff in the FAQ
d. D-series mini-me and swap
*D16Z6 block with D16A6 head
*Z6 mini-me swap
*Mini-me and engine theory
D15 OBD1 SOHC VTEC mini-me: Massive write-up
More information on swapping D16Z6 into EF
*Z6 mini-me swap
if it is the dual stage Vtec you will need the ecu for the DS vtec, or you will need a tunable p28 with the pwm kit installed so you can use that instead to control the second vtec solenoid.
as for the rest you will need to convert to OBD1 witch will require a jumper harness, complete obd1 intake(i prefer Z6)with sencors and inectors, and a Distributor.
Now search, read, search some more, read some more, and then attempt
DelSols-plural
09-13-2011 06:17 AM
JDMTuner4Life
02-24-2007 07:29 AM
