D15B VTEC Distributor - Honda-Tech - Honda Forum Discussion
Old 12-29-2017, 06:43 PM
Default D15B VTEC Distributor
What is the part number I need to use to get distributor for D15B VTEC engine?
REDDRIVER1 is offline
Old 01-01-2018, 01:19 PM
Marcos Barrios's Avatar
Default Re: D15B VTEC Distributor
let me ask you a stupid question
what honda civics come with d15 vtec motors?
and also what car do you have that you have this d15 motor in?
Marcos Barrios is offline
Old 01-01-2018, 04:36 PM
The engine came out of an Acura Integra from Japan and I put it into a 1993 Honda Del Sol.
Old 01-01-2018, 10:47 PM
no it didnt come out of a acura integra in japan thats wrong info
the d15b motor only came out in 92-2000 honda civics in japan and also the del sols 92-98
and since you have a del sol
that means that you are in the wrong section here on honda-tech
this section is for 88-91 only
but i will still help you out bud
the part number your looking for is 31-17404
and thats over at autozone
good luck
Old 01-08-2018, 10:18 PM
good luck
Yeah that was a little mean spirited.
89hybrid is offline
Old 01-08-2018, 11:15 PM
haha yea i know
i dont mean to be either
i try to help the best i can
but sometimes theres just no way to be nice about it
what really grinds my gears is when i give them the right answer and they dont care or they think its the wrong one
Old 01-12-2018, 05:38 PM
So let me ask you a question then. My sons car a 95 do hatch came to us with a d15b. Which is non vtec.. You can also see where a mechanical fuel pump use to reside. What car did this originally come in. It’s stamp d15b. There are no numbers after. So I believe it’s jdm. Any help you can offer.
Thanks
Stacy
89hybrid is offline
Old 01-13-2018, 04:07 AM
DaX
DaX's Avatar
Thanks
Stacy
Yes, this is a JDM engine (probably from an EF), originally with dual carburetors.
DaX is offline
Old 01-13-2018, 03:43 PM
I actually think I remember seeing the motor with dual carbs. It didnít specify what car though.
89hybrid is offline
Old 01-14-2018, 09:41 AM
yup on your sons 95 the motor has been swapped already
a 95 civic as far as the 1.5s go it would of had the d15b7 or d15b8
Old 05-01-2018, 12:22 PM
Hey guys! I currently own a 1991 civic EF (EC8) European model which has a D13b1 in it (pre obd). I am thinking about putting in a JDM D15B vtec engine from a del sol (eg1). I read that it perfectly fits in the EC8 but i'm not sure about What I need to convert to OBD1. Any info guys? Thanks
Nicholas
Nickym4 is offline
Old 05-01-2018, 10:32 PM
are you good with moving some wiring around nicky?
reading a list that tells you what wires are witch on your ecu
and then moving them to a new location ?
you saw the old post already on how to make a jumper harness
you can also buy one premade
you will need a intake mainifold with 4 injectors that well work with the d15 motor
as well as the ecu and distributer that are obd1
with me so far?
if so then make your own thread and well keep talking ^_-
Old 05-02-2018, 12:17 AM
with me so far?
Thanks for the reply, the engine comes with its ecu, distributor and manifold, a full swap basically but since my engine doesn't have an ecu I didn't know there was a jumper harness. Thanks
Nickym4 is offline
skhell
01-16-2018 11:37 AM
Curlybandit
09-07-2017 07:09 AM
shopa
09-08-2016 12:29 PM
alex_f15
07-24-2016 11:06 AM
Johnolantern
05-04-2016 12:45 PM
Quick Reply: D15B VTEC Distributor
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
