D15B VTEC Distributor
What is the part number I need to use to get distributor for D15B VTEC engine?
Re: D15B VTEC Distributor
let me ask you a stupid question
what honda civics come with d15 vtec motors? and also what car do you have that you have this d15 motor in? |
The engine came out of an Acura Integra from Japan and I put it into a 1993 Honda Del Sol.
no it didnt come out of a acura integra in japan thats wrong info
the d15b motor only came out in 92-2000 honda civics in japan and also the del sols 92-98 and since you have a del sol that means that you are in the wrong section here on honda-tech this section is for 88-91 only but i will still help you out bud the part number your looking for is 31-17404 and thats over at autozone good luck |
Originally Posted by Marcos Barrios
(Post 51523110)
the d15b motor only came out in 92-2000 honda civics in japan and also the del sols 92-98 and since you have a del sol that means that you are in the wrong section here on honda-tech this section is for 88-91 only but i will still help you out bud the part number your looking for is 31-17404 and thats over at autozone good luck Yeah that was a little mean spirited. |
haha yea i know
i dont mean to be either i try to help the best i can but sometimes theres just no way to be nice about it what really grinds my gears is when i give them the right answer and they dont care or they think its the wrong one |
So let me ask you a question then. My sons car a 95 do hatch came to us with a d15b. Which is non vtec.. You can also see where a mechanical fuel pump use to reside. What car did this originally come in. It’s stamp d15b. There are no numbers after. So I believe it’s jdm. Any help you can offer.
Thanks Stacy |
Originally Posted by 89hybrid
(Post 51532673)
Thanks Stacy |
Originally Posted by DaX
(Post 51532793)
Yes, this is a JDM engine (probably from an EF), originally with dual carburetors.
I actually think I remember seeing the motor with dual carbs. It didn’t specify what car though. |
yup on your sons 95 the motor has been swapped already
a 95 civic as far as the 1.5s go it would of had the d15b7 or d15b8 |
Hey guys! I currently own a 1991 civic EF (EC8) European model which has a D13b1 in it (pre obd). I am thinking about putting in a JDM D15B vtec engine from a del sol (eg1). I read that it perfectly fits in the EC8 but i'm not sure about What I need to convert to OBD1. Any info guys? Thanks
Nicholas |
are you good with moving some wiring around nicky?
reading a list that tells you what wires are witch on your ecu and then moving them to a new location ? you saw the old post already on how to make a jumper harness you can also buy one premade you will need a intake mainifold with 4 injectors that well work with the d15 motor as well as the ecu and distributer that are obd1 with me so far? if so then make your own thread and well keep talking ^_- |
(Post 51624316)
(Post 51624316)
