crx vs ef lowering springs
gonna pick up some lowing spring online. the retailer offers springs not coilovers for my 4door, crx's, del sol's & DA's too but there probably longer since the DA strut is longer ciiw but the crx spring should be the same as my 4door spring correct?
and im thinking about getting the crx springs for my 4door becuz they might be softer becuz the crx is lighter. just an assumption. im also looking for some clearification.
Re: crx vs ef lowering springs
Originally Posted by Smit
I've had CRUX JDM DC2 coilovers on my ED. You have to use EG forks on the front and JDM EG/EF/DC2 rear lower arms.
Now I have TODA EK9 coilovers on my ED. You can use the EG forks again and you can use EDM EG/ED/EE rear lower arm.
Works fine, but indeed the 1992-up coilovers are 1inch longer. So you can't really go slammed very well.
thats good info thanks. i think though coilovers are way more compatible becuz they are short and flat on both sides becuz they dont have to fit into the bottom mold of the strut. they sit on the collars. you know what i mean? one set of springs says it will fit
years 88 89 90 91 92 93 94 95 96 97 98 99 00 HONDA CIVIC
the others
88 89 90 91 HONDA CRX
93 94 95 96 97 HONDA DEL SOL (turns out del sol is heaviest) *might be hardest spring
that being said im counting the del sol's out. so its down to the crx and civic's ill ask to see both when i go to pick em up.
the others
the others
the others
EF/CRX are the same. Manufacturers make "universal fit" parts to cut down production costs. You can get generic coilover collars off ebay, and some generic springs if you want. They'll fit your stock shocks since performance isn't an issue.
surprisingly, the weight between models isn't too drastic... go cross reference them.
2211 <- sedan
2103 <- CRX
2211 <- sedan
2103 <- CRX
2211 <- sedan
2103 <- CRX
2211 <- sedan
2103 <- CRX
b17a1db2
07-22-2007 09:12 PM
GTA
05-22-2006 07:53 AM
