CRX SI '91 Wheels and Tires - Honda-Tech - Honda Forum Discussion
Old 10-12-2017, 06:19 AM   #1
Default CRX SI '91 Wheels and Tires
I am starting a K24 swap for my CRX. I plan on Wilwood brakes, and hope to be able to afford a turbo system to help make 380 horse power.
Question; I want to have a big contact patch for my tires. Anyone know what is the largest tire/wheel combination I can install with the stock fenders?
Thanks,
Lee
leeines is offline   Reply With Quote
Old 10-12-2017, 10:42 AM   #2
LankorDie's Avatar
Default Re: CRX SI '91 Wheels and Tires
I have 15x7.5 inch wide 35mm offset Konig Hypergrams with a Toyo R888r 225/50/15 and they just barely fit. -3 camber, tabs bent on fenders, even raised the car a bit to clear. To race with them I think it would be worth rolling the fenders a bit.
LankorDie is offline   Reply With Quote
Old 10-12-2017, 12:31 PM   #3
Touching My Member
.Manny.'s Avatar
I run 15x8 Rays 57DR with 225/45/15 tires. My +36 wheels will clear a rolled fender. My +25 wheels will not. Also run -3.1 degrees of camber
.Manny. is offline   Reply With Quote
Old 10-18-2017, 11:50 AM   #4
Thank you for the advice!
Lee
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
