Sunroof drain tubes - 1991 EF hatch
So, I know the drain tubes run from the corners of the sunroof pan to drains, but where do the front drain tubes dump to? The previous owner of my civic routed both front and rear tubes to the back of the car and out, but the front tube has kinked as it is rerouted in almost a full 180 degree bend. I want to put it back to the stock routing, and run it down the A pillar as intended. Can I just shove a tube down the hole and clamp it to the sunroof drain pan? Does it connect with anything further down the A pillar?
Re: Sunroof drain tubes - 1991 EF hatch
Here's a picture of how he rerouted it. I'm wondering if he didn't use the A pillar drain for some specific reason?
it should go down the a pillar and exit near where the electrical wires feed out to the doors but behind the fender.
If I feed the line down the A-pillar blindly, is there anything for it to get caught on? I would like to reroute it, but don't want to touch it until I can be sure. I popped the A-pillar plastic cover off of a CRX I have, but can't see into the pillar at all.
its hard.
the driver side has the antenna. that i have snaked by sending a fishing line on a wire hanger first.
i dunno, worth a try...
Use a speedo cable from a 70's era vette, the longest I could find. this will go down the pillar easily and be easier to pull the new tube in. I use scotch brand "33" tape, it is sticky and really thin.
Really
Dave
Really
Dave
EFJDM1
01-21-2017 09:35 AM
sharmon
11
12-16-2010 03:33 PM
slamdunkcivic
06-20-2007 09:38 AM
