crvtec for obd0
crvtec for obd0
ive search but didnt find what i was looking for. can crvtec work with obd0? anyone running this with pr3? or i need to convert to obd1 for p28
Re: crvtec for obd0 (ironchef25)
Yeah you can do that..I actually did something like that a while back..
I had b20z/b16a setup with a pr3..But since the pr3 is mapped for a 1.6 I got a vafc and fpr to the compensate for the extra fuel the 2.0litre needs..
Re: (ihateslowhondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ihateslowhondas »</TD></TR><TR><TD CLASS="quote">whats the point, go ls vtec</TD></TR></TABLE>
http://hondamarketplace.com/zerothread?id=1268955
Re: crvtec for obd0 (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Yeah you can do that..I actually did something like that a while back..
I had b20z/b16a setup with a pr3..But since the pr3 is mapped for a 1.6 I got a vafc and fpr to the compensate for the extra fuel the 2.0litre needs..</TD></TR></TABLE>
what fpr did you use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 »</TD></TR><TR><TD CLASS="quote">
what fpr did you use?</TD></TR></TABLE>
Holley..
Holley..
how did your car run with the pr3? any extra wiring needed for the swap or just straight botom swap plug and run..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 »</TD></TR><TR><TD CLASS="quote">how did your car run with the pr3? any extra wiring needed for the swap or just straight botom swap plug and run.. </TD></TR></TABLE>
The only wiring I did with the swap is adding the 4 wires for vtec like I would any b16a swap..
The car ran decent with the pr3..But when I added the vafc and fpr it ran perfect to my needs..
The car ran decent with the pr3..But when I added the vafc and fpr it ran perfect to my needs..</TD></TR></TABLE>
was there bogging issue with pr3? how significant was the change from no vafc to with vafc. also i have a b16 already on it. so basicaly no wiring for me right?
No there was no bogging issue..Just it was running lean..Hooked up a friends wideband and it was to lean for my comfort..So I hooked up the vafc and fpr and did a ghetto street tune..It ran fine up untill the end..
No wiring needs to be done for you..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 »</TD></TR><TR><TD CLASS="quote">what about fuel rail. anything needed?</TD></TR></TABLE>
No..Everything on the b16a head stays the same..
Ignorance is bliss
The point is a crv/vtec could hit 200hp easily when the ls/vtec can''t hit 200 that easily.
Ignorance is bliss
Get a obd-0 b16 head (b16a1), obd-0 injectors, and a obd-0 distributor, and pr3. And you can run the crvtec obd-0. The block has almost no preference what obd-0 its run. Its mainly the head. If the head is obd-2, run it obd-2.
