crank pulley color code paint?
#26
Re: crank pulley color code paint?
Rofl, I have to back up here a second. Op, how exactly did you adjust your S2 cam gear? It should be set to 0, unless you're using a degree wheel to "degree" your camshaft. <-- That's how you find true top dead center for the mechanical timing of the engine. Again, you're mixing up mechanical and ignition timing. Stop it... just stop it! :]
its off because im use a d16a6 block with a d16y8 head. as quoted earlier by "N3va3vaSatisfi3d", he said that the combo makes the head off by half a tooth.
1 tooth = 9 degrees.
1/2 tooth = 4.5 degrees.
so i am setting it at 4.5 degrees to compensate.
#27
if i set it to 0 it would be off.
red civic standard
09-27-2004 09:02 PM
iperez
06-24-2004 06:58 AM
