CR with B18B with ITR head/cams
would changing my head from a stock ls to a stock ITR head with ITR cams change the compression ratio?
IF so from what to what?
I am wondering if I should go ITR head when I turbo my car....
thanks alot
your friend
Sean
thanks alot
your friend
Sean
Re: CR with B18B with ITR head/cams (redbullapril23)
Yes it will increase but not very much if you stick with the stock PR4 pistons. To get the most out of the setup you need to run different pistons like the PR3, P73, P72 or PCT pistons.
stallinrawlings
19
04-17-2014 01:23 AM
