continuous fan switch problems
hey guys, im back with my 1990 honda civic hatchback, D15B1
last summer my cooling fan spontaneously stopped working, causing my car to overheat any time i sit in one spot more than 3-4 minutes. replaced the fan switch, which was a pain in the *** to get to, and everything worked fine after that.
so what is my issue?
fan has stopped working yet AGAIN. everything ive seen points to the switch or the relay being bad.looking to do a Z6 mini-me in the near(ish) future, but wanted to get the fan sorted out first. has anybody else had their fan switch fail repeatedly? replacing the switch every summer is going to get old real fast...
Keyboard Humorist
Re: continuous fan switch problems
Fortunately, the Z6 has the switch located on the thermostat housing.
I would get under the car and jump the connector wires together to verify if you existing switch is bad or if it's something else.
that would be weird if your switch is failing so quickly.
thats kinda what i was thinking too,
im actually working on a brand new harness for the Z6, but have a lot of work left before im ready for the swap.
that with the warmer weather is literally the only reason im looking into the cooling system issues, so i figured id see while im at it, if anyone else has ever had repeated malfunctions with their fans.
My mate did,drove his nuts after replacing parts and still overheating on warmer days.Finially took it to an auto electrician to find out the previous owner had wired the wires to the fan wrong.
fortunately, the wiring harness is one of the only parts in this car that the previous owner had NOT tampered with, (when i did my MPFI conversion, i simply bypassed the old wiring by disconnecting the ecu pins and replacing them with new wires for the injectors and the 2 distributor wires, with a jumper for the distributor) and the fan worked when i got the car 3 years ago, it suddenly quit working once the weather started staying above 80 degrees, i replaced the switch and it worked again right up until we had another hot week.
made a wire jumper last night with 2 bullet style connectors and turned the key on and fan worked. no idea why the switch would spontaneously fail when it gets hot, so i think ill just wire it up for the Z6 t-stat housing for the time being. then i wont have to change the thermostat and housing when i do the swap since itl already be there.
have you guys had any issues running the stock EF hoses with the different outlet angle of the z6 housing?
