Brake pedal soft when car is on
I bled, I changed the master cylinder, brake booster hose has air when I unplugged it but I still can’t figure out what’s going on. Nothings leaking. When car is off brake pedal get stiff but when car is on it goes soft, can’t figure It out help |
Re: Brake pedal soft when car is on
Can you explain us how did you bleed it?
Originally Posted by Josip.
(Post 51894729)
Try gravity bleeding starting at the caliber furthest from the master cylinder |
Soft as in it goes all the way to the floor, or just softer than it is with the car off? If the latter - this is how a vacuum booster works...it makes it easier to press the pedal.
Originally Posted by DaX
(Post 51894796)
Soft as in it goes all the way to the floor, or just softer than it is with the car off? If the latter - this is how a vacuum booster works...it makes it easi er to press the pedal.
Never mind, I found out why. My brake calipers was upside down on the wrong side. I put the left one on the right and vise versa. The bleeder nipple was facing down when it was suppose to face up. |
