headgasket or something else?
im waiting for a friend to bring his compression tester as we speak and ill leakdown after depending on results. Anyway its a b20 i see white smoke when its cold but im running straight pipe with no cat. i see water coming out of the pipe but with the temp i think its normal. car sputters and hesitates a little . heres the thing tho. no mixed fluids at all, car stays below half with temp, but im burning coolant on my fourth cyl. umm help?
Re: headgasket or something else?
White smoke is water, or moisture in the pipe, and since your in florida and its been getting colder a cold start would do that, does this continue after driving for a while or does it go away?
DO IT ON ALL FOURS
Yes, this is a possibility (since obviously the intake port is right next to the coolant port).
honestly after adding up my reciepts that i have from JUST the b20 im already at $4162.54. thats not including converting the car to manual when it was a single slammer. i would say my 200 dollar car has me at almost 4500 dollars in 16 months. im so tired of it. I took the fouled plug to a few places and they all said i was burning coolant and i know that its true. ill see today i guess if its the intake.
/rant
/rant
DO IT ON ALL FOURS
Glad to hear you got it fixed. Next time, show me a better picture of the spark plug from a top view showing everything and I could have pin-pointed it better for you. At least I helped you get it on the right track though.
eg4metodrive
02-20-2006 05:05 PM
buck02
05-28-2004 09:12 AM
