b16 vacume diagram.
I searched and found this
https://honda-tech.com/zerothread?id=600150 Like 3 post down someone put a diagram. Now my question is. Mine isnt the same as that but i have no codes and pass emissions but i have lines that go nowhere and i want to clean it up a bit. Now you see like #1 comming off the FPR and it goes to the pressure regulator soleniod cut off valve, than into the back of the Intake manifold. Well mine goes right from the FPR to the back of the intake mani. Is this proper? I have that soleniod but its not hooked up. -Eric |
Re: b16 vacume diagram. (HamiltonRex)
yes that is fine also. mine is ran from the fpr right back into the back of the intake mani.
Re: (88crex)
I hooked up my vacume lines using this diagram.
http://texas.clubsi.com/brandon/crx/vacuum.jpg It says D goes to intake Hook up A and B using a T fitting than hook them to F C hooks up to H I hooks up go G E hooks up to J Everyone says to go from the FPR to the back of the intake. If i do that do i just cap off where it says 'F' is? (the hose it says to connect with A and B). And on my intake manifold i have another similar looking piece beside where hose "d" is hooked to. I have hose D and the hose coming off this similar looking piece together with a T than going into the Intake, is this alright? Now it says that the stuff mounted to the firewall is the map sensor and the solenoid, well on my 88 crx si i have 2 solenoids, with the 2nd one can i just discard it? It is wired up to something are thoese just dead wires and are not being used or should i just cap off the openings on the extra solenoid? Thanks! -Eric |
In that diagram. I have all the connects but there is another connection next to D that I have. Where does that go? If you look at the 1st picture on http://www.geocities.com/phato....html then you'll see which part I'm talking about. THanks guys
Re: (streetslicks)
yeah man i know what your talking about, just get a T and connect it with D and than go to the intake. Thats how i have it, no codes, perfect idle, no flat spots etc.
-Eric |
