b16 into 4g sedan, few questions
New User
I have a few questions on what to order for my b16a.
Spark plug wires (99-00 si?)
header (any clearance problems w/99-00 si?)
cold air intake (assuming trunk mounted battery) which will work?
Which motor mount bushings should I get for hard driving and autocrossing?
Thanks
PS, I know the recommend routes but I would like to hear from those who have first hand experience cause there is always more than one answer.
Thanks
Re: b16 into 4g sedan, few questions (4G-CIVIC)
any sparkplug wires off any b-series VTEC motor will work (b17a, b16a, b18c), as well as 88-95 1.5 DX and 88-91 1.6 Si
92-3 GSR will work, 94-97 del sol VTEC, 99-00 Si coupe all are good...as well as ITR....GSR will be to short....
most 88-91 civic Si intakes will work like a charm
what kit are you using....if HCP or Hasport or PR, no need for....if you go with a weld in then, ES bushings are excellent....
New User
Re: b16 into 4g sedan, few questions (eg6ajk)
OK, I will tell you that header fit (DC 4:1) was TIGHT with b16a in my 91 Civic EX with HASport mounts, and so I had to get the PlaceRacing front crossmember for any kind of fit....
I got the NGK plugwires for B series motor - good....
Watch and make sure you get the right axles as with my S1 tranny they sent me 90 LS Integra axles, but they were from an AUTOMATIC, and did NOT fit....
