b16 high idle
b16 high idle
i have a b16a 93 civic hb and my idle is to high and sometimes the idle moves up and down from 1,400 to 2,500 rpms i triggered the ecu and i got codes 36( traction control..found on jdm ecu's) and code 41 (primary oxygen sensor heater) what is that primary oxygen sensor ?,...........does n e body have a pic? i already checked for vacumm leaks but there isnt n e how can i fixe my idle problem?
Re: b16 high idle (carlosd68)
nice first post lol....anywas the idle is most likely due to your IACV (idle air control valve) located on the back of you intake manifold with 2 coolant lines going to it. This seems like you have a wrong ecu or something for the setup, there are not two o2 sensors on an obd-1.....maybe im wrong but first off you should post this in the tech or eg+ forum....a 93 civic hatchback is an eg buddy...gl...and for future reference its vtec not vtech lol....not that you said that, but almost every new poster does at some point
