A6 intake manifold on DOHC
Is a DOHC ZC IM better than the A6 IM..I have a Si now and if the a6 is better why not use it I guess. Do you i use my a6 dizzy? Also does the dohc zc put around 125-130hp at flywheel? Ive read they put from 115hp-135hp @ flywheel
Re: A6 intake manifold on DOHC (FullMetalJacket)
u cant use the DOHC zc mani on an a6 they dont bolt up
Re: A6 intake manifold on DOHC (crxecution)
oh and btw, the black cover DOHC ZC is rated at approximately 105-110 at the flywheel. |
Re: A6 intake manifold on DOHC (beta13)
oh and btw, the black cover DOHC ZC is rated at approximately 105-110 at the flywheel. I think you are talking about the SOHC because the lowest I've seen the ZC rated is 130. yeah black cover DOHC ZC is 130, brown is like 110 |
You cann't use a ZC intake on a A6. The mounting points on the block are different, would have to rework it. Get a Z6 or Y8 manifold, bolts right up. Would say yes for the horsepower sounds about right in JDMland they measure H/P at the flywheel while in USA its at the wheels. About the Diz what are you asking, dont understand what you are saying/askin
Re: A6 intake manifold on DOHC (zCivic)
A6 Dizz will not work on the DOHC, it doesnt mount up, supposedly you can cut off two of the legs and use it but its a major hack job. I think you have to flip the rotor too, its way more trouble than its worth, if you need and ZC distributor parts or the the sensor on the exhaust cam (Cylinder position sensor) just ask, I have a bunch of ZC stuff left over.
These are pics of the two intake maniflods, this is the DOHC ZC
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D This is the D16 http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D Youcan see the difference in the bolt patterns right away. This should clear up any confusion you may have. |
you have your number mixed up
brown top ZC- 130-135 FLYWHEEL HP Blacktop ZC- 130 FLYWHEEL HP which is about 110-115 WHEEL HP aka WHP... flywheel hp > than WHP...always... |
Re: A6 intake manifold on DOHC (crxgator)
What other fuel rails will bolt up to the ZC intake manifolds?
Re: A6 intake manifold on DOHC (Quazi Boosted PeloTudo)
What other fuel rails will bolt up to the ZC intake manifolds? |
