91 CRX Si Rebuild
#52
Re: 91 CRX Si Rebuild
going into storage baby
head, block, tranny, crank all wrapped. fingers crossed.
#54
Well decided to grab another storage unit to allow me to work on the crx in one. New fuel tank with a Walboro & 12awg wire routed. Painted the fuel tank with Duplicolor Rubberized Undercoating but overall it scuffs easier then i would have liked. Figured its just another layer of protection. Added the original boots over the power and ground wire in tank its just not pictures. I will be adding the fuel pump relay tomorrow.
#56
#58
Knock off ktuned shifter and some cheap Amazon shift ****.
Wired up plx wideband, autometer boost and oil pressure gauge
Mounted the gauges here as the wires just drop right down. No drilling or anything. Being held down with some 3m tape
Reutilizing the factory fuel filter bracket.
The corners are rounded on the bracket now just not pictured.
CS style front lip arrived...loving this at the moment. Can’t wait to mount it and see it
#59
@mynameisjustin
Thread updates?
Saw the recent video, where was the best deal for ordering the exhaust? running a cat or test pipe?
Thread updates?
#61
Just got her on her first day I’m so stoked. Out 8 miles on her. She’s sitting now so I can see any leaks. Up to temp no leaks occurred. It looks like the valvecover gasket by cam caps on the dizzy and seal end may be leaking a little
NRG Shorthub, QD, and NRG wheel
Little tire sticker action
CS Style lip mock-up
#62
Dude more picutres of the car together PLEASE!
What did you do for a throttle cable? I have the same manifold, and so far I cant make the bracket that came with the manifold work at all.
#65
She DRIVES. Had some issues like grounds and had to recal the TPS but so far I’m happy. Still lots of little things to do but she’s getting there. Lank sorry I’ll post a picture tomorrow of the throttle cable. I used the bracket supplied and moved it over. Only being held in with 1 bolt
#66
Decided to install the Omni 8k tach as it matches the stock engine redline a bit better
Installed
I have always loved the stock edm wing
Some may call it blasphemy BUT since I got rid of the rear wiper I decided to fill the hole and then paint over it
Gregparts makes some quality 3d printed parts Incase no one has checked him out
Damn I love how she’s turning out :D
Engine bay as of now...turbo will still soon be in the future. She just hit over 450miles
Little self powered 8” kenwood sub was the perfect add on to fill out the sound in the car.
#68
@mynameisjustin
Thread updates?
Thread updates?
#70
That's a great color, love how it looks on your Si. Looking forward to seeing how you wire up the fogs; need to do that myself. The one caution I would give you is that if you're going to track your car, I would replace that NRG steering wheel. They do tend to collapse much more than the other normal brands. But great build.
#71
Shes at 940 miles now and running well. I thought i had a small tranny leak which ended up being a small prop valve leak that leaked down onto the tranny. Tricky little leak :D. Autopower roll bar, Cobra Bra & Floormats have been added. Recently ordered an X600 Series Turbokit from Go Autoworks. Decided on a GT2871rs to continue making this a fun streetable car.
#74
WOW! looks awesome! What kind of front lip is that? Wish there was a pic without a raised hood. Would look much cleaner imo. Subscribed.
