91 crx injectors? help please!!!!
ok i traded for this car its a 91 crx dx with si tranny it has a d15b7 it has like 106 hp and my 96 civic dx has d16y7 almost same specs but its faster than my crx i think the injectors are mest up cuz when im just touchin the gas a little it kinda starts cuttin out and when i punch it its like there isnt much power until i get to like 5500 and its starts pullin hella hard please help if you think its my injectors or somethin else thnx https://honda-tech.com/forums/images/smilies/emthup.gif
Modified by jdmEK209 at 7:04 PM 6/11/2006 |
Re: 91 crx injectors? (jdmEK209)
bump for help
bump
im not to much king with d series but i believe thats when your gas starts to pump in your cylinder causing a chain reaction with combustion and your intake and exaust valves open and close from your cams and rebound with springs and then your cams turn from your crank shaft which is called timing and the it moves your pistons up and down repeating the whole process.. just couple rps faster https://honda-tech.com/forums/images/smilies/emwink.gif if you want to konw more i can tell you for just 5.99 a month
Re: 91 crx injectors? (jdm91CrxSi)
first check your basic shits.
timing plugs plug wires dizzy. go from there. |
Basic tune up, replace fuel filter. Get some injector cleaner in that gas, just to help it out.
bump
what intake manifold are you running? if they used the stock dx manfiold dpfi thats why. if they converted it to obd1 then there is definitly a problem.
Re: (extensioncordy)
well the motor is d15b7 but my boy said its a ex intake manifold and its obd1
Re: (jdmEK209)
http://i60.photobucket.com/alb...5.jpg this is the setup
Re: (jdmEK209)
bump
