88 CRX BUILD
1988 HONDA CRX
POWERTRAIN: 96 SPEC ITR (B18C) DRIVETRAIN: J1 B16 W/ LSD BUILD SHEET ENGINE: JDM B18C ITR BLOCK CUNNINGHAM I BEAM CUSTOM RODS ARIAS 11.3:1 COMP 81.5MM PISTONS W/RINGS OEM ITR CRANKSHAFT ACL RACE BEARINGS STD OEM OIL PAN ITR HEAD PORT N POLISHED SUPERTECH DUAL VALVE SPRINGS SUPERTECH NITRIDED VALVES SUPERTECH VALVE GUIDES W/ SEALS SUPERTECH RETAINERS W/ KEEPERS SPEEDFACTORY VTEC KILLER PINS GSR CAMSHAFTS W/OEM GEARS GATES RACING TIMING BELT EDELBROCK PERFORMER X MANIFOLD PROFESSION PRODUCTS 70MM TB RDX INJECTORS AEM FUEL RAIL AEROMOTIVE REGULATOR W/ GAUGE HOLLEY FUEL PUMP W/INLINE FILTERS CJS TUCKED WIRING HARNESS OBD 1 HONDATA S300 V3 TRANSAXLE: SMALL SPLINE J1 B16 W/ LS 5TH GEAR SYNCHROTECH PRO SERIES CARBON LINED SYNCHROS "OG" OBX LSD OEM BEARINGS OEM B SERIES AXLES ACT CLUTCH/ PRESSURE PLATE/ FLYWHEEL EXTERIOR/INTERIOR/SUSPENSION: VIS CARBON FIBER HOOD PROGRESS COILOVERS AVID RACING TRACTION BAR COMPETITION ENGINEERING 4PT ROLL CAGE SPARCO SPRING SEAT CORBEAU 4PT 3'' RACE HARNESS 15'' DRAG DR29 CRX SI PASSENGER SEAT SKUNK 2 UCAs BWR LCAs MOOG TIE RODS THE DAY I PICKED IT UP https://i824.photobucket.com/albums/...ps23de118f.jpg N/A B18C ITR https://i824.photobucket.com/albums/...ps9392a0aa.jpg Si seats in near perfect condition https://i824.photobucket.com/albums/...psa957f298.jpg |
Re: 88 CRX BUILD
Pulling the motor day by day
http://i824.photobucket.com/albums/z...ps15c84a76.jpg http://i824.photobucket.com/albums/z...ps1147811f.jpg http://i824.photobucket.com/albums/z...psdfcf330d.jpg http://i824.photobucket.com/albums/z...ps3beae7ac.jpg http://i824.photobucket.com/albums/z...psa96b8f53.jpg http://i824.photobucket.com/albums/z...psb37b5332.jpg As you may already see those pistons don't look right for a supposed OEM engine... I look for the p73 cast marks but they aren't there. Why do these pistons look so weird? Oh wait they're not OEM at all!!! Custom cunningham I beam rods w/arias high compression pistons!!! SCORE http://i824.photobucket.com/albums/z...psc6a3c89b.jpg |
Re: 88 CRX BUILD
What the CRX has gone through over the years from contact of previous owners!
http://i824.photobucket.com/albums/z...ps9b5863ec.jpg http://i824.photobucket.com/albums/z...psb5b95c4a.jpg http://i824.photobucket.com/albums/z...ps2a743f12.jpg http://i824.photobucket.com/albums/z...psbca5ef6a.jpg http://i824.photobucket.com/albums/z...ps4d119b5f.jpg |
Re: 88 CRX BUILD
Teardown of the J1
http://i824.photobucket.com/albums/z...ps56d8165b.jpg http://i824.photobucket.com/albums/z...psf4addc6b.jpg http://i824.photobucket.com/albums/z...ps1df0ee11.jpg http://i824.photobucket.com/albums/z...ps58670294.jpg http://i824.photobucket.com/albums/z...ps4fa7c010.jpg Cleaned up case http://i824.photobucket.com/albums/z...psf0fa7bee.jpg |
Re: 88 CRX BUILD
Looks like its coming along nicely!
Re: 88 CRX BUILD
Yes it has. I started about 6 months ago and I'm moving nonstop with this dream build of mine. I'm taking my time though and making sure no steps are cut short... Do it right the first time!
Re: 88 CRX BUILD
SUPERTECH VALVETRAIN
http://i824.photobucket.com/albums/z...ps8d29c55a.jpg AFI RAMHORN http://i824.photobucket.com/albums/z...ps8a82aa61.jpg PERFORMER X MANIFOLD W/ AEM RAIL AND DEPLHI INJECTORS http://i824.photobucket.com/albums/z...psa1d0ab42.jpg |
Re: 88 CRX BUILD
Started the rewiring of the car
Re: 88 CRX BUILD
Its nice to see some some quality performance parts! Good luck on the wiring
Re: 88 CRX BUILD
Thanks appreciate that
Re: 88 CRX BUILD
I've decided to start this build going all motor and after I feel comfortable in circuit I'll go ahead and move to boost!
Re: 88 CRX BUILD
RIGHT NOW IM TRYING TO FIGURE OUT HOW TO RETAIN ALL MY FORCED INDUCTION PARTS AND CONVERT BACK TO ALL MOTOR. IM SWAPPING OUT MY CP PISTONS FOR HIGH COMPRESSION ARIAS PISTONS. LOOKING TO GET MY DISHED VALVES SWITCHED FOR FLAT VALVES FROM MY LOCAL SHOP REVLINE IN KANSAS CITY. IM GOING TO FIND A SPARE BLOCK SINCE I JUST TRADED MY BARE BLOCK TO A BUDDY SO I CAN TAKE MY TIME SENDING OUT THE BLOCK TO GOLDEN EAGLE FOR SLEEVING. I THINK THAT STARTING OFF ALL MOTOR VS BOOSTING WILL HELP ME TRANSITION AROUND THE CIRCUIT TRACK GETTING THE BEST FEEL FOR THE CRX SUSPENSION WITHOUT OVER POWERING AND POSSIBLY LOSING CONTROL OF MY HANDLING. WHEN I FEEL COMFORTABLE ILL SWITCH AND HOPEFULLY A FEW EXTRA POUNDS DOESNT THROW OFF THE WEIGHT AND HANDLING TOO MUCH. ILL KEEP THIS BUILD THREAD UP TO DATE AS MUCH AS I CAN.
Re: 88 CRX BUILD
Wiring harness is a pain in the butt!!!
Re: 88 CRX BUILD
TAKING A BREAK FROM THE WIRE BUNDLE! DECIDED TO START TAKING THE HEAD APART AND SWAP PARTS OVER TO MY SPARE HEAD.
http://i824.photobucket.com/albums/z...pskk3t8w3j.jpg http://i824.photobucket.com/albums/z...ps333a5yzc.jpg TYPE R DUAL VALVE SPRINGS http://i824.photobucket.com/albums/z...psvgf0na2g.jpg http://i824.photobucket.com/albums/z...psolihug4o.jpg |
Re: 88 CRX BUILD
dose anyone know if I can use a 97 1.5 block with the 90 crx head and fuel system
Re: 88 CRX BUILD
Umm need more info and please don't ask these questions on my build thread! I suggest you start your own thread
Re: 88 CRX BUILD
TYPE R STOCK PORTING
http://i824.photobucket.com/albums/z...psirc0ibnh.jpg TIME TO GET THE REST OF IT PORTED AND GASKET MATCHED http://i824.photobucket.com/albums/z...psaeuyywke.jpg |
Re: 88 CRX BUILD
This is looking pretty sweet so far. I just rebuilt my trans. w/ Synchrotech Carbon's too. They're smoooooth. Good luck with the build.
Re: 88 CRX BUILD
Watch out with the intake porting, theres a way to port them. It wont work if its all polished. The gaz will get into the combustion chamber as a drop. Make sure the entering of the combustion chamber is more like oem porting. (not polished and raw alluminium)
Re: 88 CRX BUILD
Porting and polishing decreases turbulence from stock castings and allows quick transition through the inlet and outlet ports!?! Anyways I don't plan on polishing it just a mild port job. I'll pay for someone to do it any further.
Re: 88 CRX BUILD
Originally Posted by GreenMonsterEK
(Post 49412941)
Re: 88 CRX BUILD
Why would fuel get into the combustion chamber as a drop? If that happens I've got bigger things to worry about!!! (i.e. bent rods) Hopefully my injectors spray correctly and my air flow/venturi affect atomizes the fuel. I still don't get how porting my inlets ports will change that?
Ported head http://i824.photobucket.com/albums/z...psrxifuert.jpg |
Re: 88 CRX BUILD
WATCH THIS VIDEO... ITS WHAT MY INSTRUCTOR RECOMMENDED
http://www.powerblocktv.com/episodes...r-power-how-to |
Re: 88 CRX BUILD
wow
