View Poll Results: What you think?
Multiple Choice Poll. Voters: 48. You may not vote on this poll
1991 EF sedan build from TX
1991 EF sedan turbo build from TX
car has already been swapped to B series with a poor mans. built, pistons, rods, block guard etc, valvetrain an all . All I need to add is cams.
built motor with a block guard for now by TURBO RIC
Turbo Elements manifold
precision 6262
Turbo Elements 3" Downpipe
TiAL 44mm Wastegate
Turbo Elements Fuel System (Sump Tank, Bosch 044, Hard Line, GE Fuel Rail Bosch 2200cc Injectors, Areomotive FPR)
Turbo Elements Dual Backdoor Intercooler (Garrett Core 24x12x3.5)
Turbo Elements 3" Intercooler Piping
TiAL Q 50mm BOV
Battery Relocted to the trunk, with remote kill switch
Extended Studs
Full-Race Traction Bar
BWR Half Core Rad, modified to fit EF chassis, w/14" Slim Fan
pics as of 1/17/2017
precision 6262
TiAL 44mm Wastegate
TiAL Q 50mm BOV
Extended Studs
Re: 1991 EF sedan build from TX
I like the Fit wheels. I just bought a pair of EFs. Got a '91 (I think) hatcback with a GSR engine and a B series cable trans. Hatch is a little rough so I'm swapping it into a '91 Sedan.
I'll be following this build because I want to do something similar with mine.
EDIT: Forgot my question. You got info on the traction bar install? I saw you used a Full Race traction bar. I found a link to a writeup but it was a dead end.
rims are 15s actually. they come 16s too but sorta hard to find atleasts here lol.. for the traction bar it was a direct bolt on I was told . Tim from Turboelements from AZ thats here in TX now put it on since the car is at his house and he is installing my turbo and doing my intercooler set up etc and the fuel system.
and not really trying to make 600hp on e85 until i get my sleeved block then turn it up somemore.
right now the block is built with a block guard should be enough for now.
top mount got a great deal on it from turboelements and could not say no, plus trying to build a little different ef than usual, plus around here there is none like this one just yet in SA or maybe even TX
i feel you on being different. im going to be running a built engine on stock sleeves topmount with sc61 turbo. my efsedan is unusual already lol. its cause we dare to be different.
should find Jason's thread here somewhere. efsedan, caged, built, front mount turbo, full interior etc going 11.2's spinning. username: ef4dr i think..
yeah cage is next after this is done with full interior etc nothing taken out. and a hydro conversion. im confident the car will be in the 10s with this set up if i can get it to hook. we got a few eg's here at 350hp only running 11.3s and can get a bit lower soon on stock bottom ends. so we will see should be interesting..
bro i need some pix of the tp with turbo and down pipe also the wastegate/dt..im trying to get the setup soon, but spoolin and some other company are saying that they wouldnt suggest that i go tm cause the fitment is very tight. i really want it but i want make sure there are room to run the components.
