00 civic Si cluster install preview (pics)
#51
Re: 00 civic Si cluster install preview (bossman032)
Not yet. I am going to wire everything up tommorow except the VSS which I havn't revieved yet. Once I do I will post and let you guys know how it went.
-James-
-James-
#55
Re: 00 civic Si cluster install preview (wu tang)
It was only the wire colors that didn't match up. I don't know off hand which they were but this wiring chart should tell you. Just look at the wire colors and see which aren't the same
-James-
-James-
#58
Re: 00 civic Si cluster install preview (drift2live)
nice work dude for you, i'll do a writeup like this on our prelude cluster into a EF project
#60
Re: (Carnivore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carnivore »</TD></TR><TR><TD CLASS="quote">jus curious on how you are going about swapping the odometer unit of your old cluster to put on the new SI one so you have your correct mileage on it</TD></TR></TABLE>
Just open it up and adjust to whatever mileage needed.
#61
Re: 00 civic Si cluster finished write up and PICS (B18C5crx)
does the fuel gauge work? someone said that you have to change the tank sender unit from a integra. also does it scres right into the sh3 gauge mounts or are you using mounts from the civic si?
#62
Re: 00 civic Si cluster finished write up and PICS (avirex_man_2000)
The fuel guage works ( I have no gas in my car thats why it looks like its on E) Its the low fuel warning light that doesn't work because the crx doesn't have the low fuel sensor in the tank. You can install one from an integra and just wire it up to the cluster in pin location A8.
The cluster is just sitting in there. It is not bolted down. All you have to do is remove the 2 metal mounting brakets from inside the cluster bowl and place the cluster in and then slide the guage cover over it. The guage cover will hold the cluster in place, it is a very snug fit. The cluster didn't move around or rattle when I drove the car around the block. If you want, you can drill 2 holes in the roof of the guage cover and put 2 screws into the civic cluster mounting tabs, just make sure they are lined up properly.
-James-
-James-
#64
Re: 00 civic Si cluster finished write up and PICS (bossman032)
91 crx Si. The wiring is the same for all 90-91 models. If you wanted to put it in an 88-89 you would need a 90-91 guage hood. I am still working on the wiring it is pretty similar to the 90-91 alot of the colors are the same but the pin locations are different.
-James-
-James-
#65
if I wanted to put it in a 91 civic would I need to have the crx gauge hood or would my civic one fit??? (they ARE different).....
#66
Re: 00 civic Si cluster finished write up and PICS (lemonhead)
Ya know Im not to sure about the civic. I would assume it would fit in the 90-91 civic hood since it is rounder and has more room. It may not fit the same but the wiring is the same. The only real way to tell is try it out for your self. Sorry I couldn't be more helpful.
-James-
-James-
#67
I took way too long
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx »</TD></TR><TR><TD CLASS="quote">Ya know Im not to sure about the civic. I would assume it would fit in the 90-91 civic hood since it is rounder and has more room. It may not fit the same but the wiring is the same. The only real way to tell is try it out for your self. Sorry I couldn't be more helpful.
-James-</TD></TR></TABLE>
More rounder than what? The 88-89 yes but not more rounder than the 90-91 CRX.
#68
Re: 00 civic Si cluster finished write up and PICS (slowman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman »</TD></TR><TR><TD CLASS="quote">
More rounder than what? The 88-89 yes but not more rounder than the 90-91 CRX.</TD></TR></TABLE>
That is what I meant. rounder then the 88-89 guage hood. I would assume the 90-91 civic guage hood and the 90-91 crx hood are similar in size or are the same thing. Can anyone clarify this for me?
-James-
-James-
#69
I took way too long
Yeah OK, that's what i thought you meant!
And I do not think it would work in a 90-91 civic gauge hood because all though it is rounder than the 88-89, it's still 'flat' on the top. I believe this will only work in the 90-91 CRX gauge hood.
#70
will a crx gauge hood fit in a civic??? if no one know's i'm going to the junkyard on mon or tues and i'll find out
#75
Re: (XXXRacing)
Ok I have moved everythign to the first page so yo udon't have to look through 3 pages to find the info for new info and a cool looking cluster.
-James-
-James-
