00 civic Si cluster install preview (pics)
#26
Re: (1CAMcan)
When I get home I will let everyone know the wiring. I have it all worked out. Im just waiting for the VSS and clips to get here and it will be in and I will have a write up.
-James-
-James-
#27
be professional
Re: 00 civic Si cluster install preview (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam »</TD></TR><TR><TD CLASS="quote"> http://cgi.ebay.com/ebaymotors...33675
That's just HOT</TD></TR></TABLE>
He says it's from Japan, but it's not. It's a Canadian EM1 SiR cluster.
The JDM EK4 SiR cluster looks completely different.
#32
Re: (Carnivore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carnivore »</TD></TR><TR><TD CLASS="quote">jus curious on how you are going about swapping the odometer unit of your old cluster to put on the new SI one so you have your correct mileage on it</TD></TR></TABLE>
lol, **** correct mileage
#34
Re: 00 civic Si cluster install preview (bucbaby)
Once my Vss gets here it will be in give me a few more days and I should have it up and running. I have some wiring info but i just need to upload some pics and I will post that up asap. I am not to worried about correct mileage since I plan on keeping the car forever.
-James-
-James-
#37
Re: (Carnivore)
If you had the time-a drill and a cable.Just add the miles to it.
#43
Re: 00 civic Si cluster install preview (B18C5crx)
how are you going to wire in the vss? Is this even possible? They are totally differnt, , considering 1 is a cable and one is a plug. Looks dope though very impressive.
#44
Re: 00 civic Si cluster install preview (riceboyEFsi)
To wire in the vss. You need to take out your cable driven vss in the tranny. And replace it with a 92+ civic or 94+ integra electronic vss with the 3 wire plug. ANd wire it up power ground and signal. Its easy.!
Btw. I was the one who wrote up the integra cluster swap. I was actaully going to do a si cluster in my car. But I sold it and just put the gsr one in.
#45
Re: 00 civic Si cluster install preview (ghettocrxsi)
Yes you have to use an electronic VSS from a 92- civic or a 94- teg. From what i have read it is easy to wire up. I will soon find out.
Hey Ghettocrxsi I have to thank you for your write up on the teg cluster I used it as a guide.
-James-
-James-
#48
Re: 00 civic Si cluster install preview (bardo)
i had the same idea, have the new plugs and gauge cluster sitting in my room just waiting. i did a test fit on my 89 si and it was coming up short, just need to pick up the VSS and the 90-91 cluster surrounda and try another test fit.
so how are you actually securing the cluster to the dash?
#49
Re: 00 civic Si cluster install preview (silverkorn)
Bump for editing. I was originally using 88-89 Si clips but the wire placement was different then the 90-91 So I changed the clip pics for the 90-91 clips and everything should be fine now.
-James-
-James-
