Rd1 lifted turbo build
#51
Re: Rd1 lifted turbo build
well... in my buddies focus when his back windows are down it makes that God awful helicopter noise so he bought "rally vent", kind of gives his car a cop car look. Let's air in without the noise. Will it be functional on the crv I highly doubt, but I'm going to give it a try.
#52
Been awhile. Have some videos to post tomorrow. Boosting to the 7lb wastegate, 1st gear worthless going to set up boost by gear. Oil drip damnit
#54
https://youtu.be/aU0zShLyqwo
had to do some night time datalogging. Sorry about crappy video. Closed exhaust pull around 0:05, open exhaust pull around 2:13. Needs rear diff and alignment still. More videos coming soon.
Boost set to 7lbs
Boost set to 7lbs
#56
Fish Twig
HI, just found this build thread. Check the 92-00 civic section for where to cut and solder in the temp wire. I never got around to test it but no one who has bumped that thread has come back with any issues.
#57
will try to find it thanks a ton still havent figured it out
#58
Found a cheap umbrella going to get some Honda decals for it.
next big thing is a motorcycle trailer
Amazon special
Amazon special
Last edited by On1wheel; 11-10-2018 at 07:18 AM. Reason: Next big thing now is a clutch because the shit one in it just fried at 7.5lbs
#60
Moderator
Originally Posted by On1wheel
http://youtu.be/Z-UxqGLE9hQ
https://youtu.be/iXoiIZ0HmN4
Needs alignment for sure.. looking for a front sway bar
#61
Going to see how they compare in some mud have some video and pics in next few days.
Definitely have to say thanks to all the lifted/many non lifted builders that made threads. From the short throw shifter to the size of the tires, all ideas from this forum. Comp clutch in route
#65
It made a loud click noise when I first turned the wheel but I've drove it around and seems to be fine. Taking it off soon to leather wrap it so I'll know then but I is working
#66
Steering wheel feels nice and buttons working no issues so far. Have some shaking in front, found this...
Orielly axles are junk! Plus the angle from lift is causing the inner and outer boots "ribs" to rub. Looking for oem. Driver side inner tie rod shot also. Picture is with wheels off ground
sleeperhatch91
10-09-2005 03:09 PM
JDMTurboCivic11
02-23-2005 05:50 AM
