Honda CR-V & Element 2WD & 4WD Element & CR-V
Post pictures of your first gen CR-V project.
Old 02-20-2012, 01:21 AM
  #126
DualCamDan's Avatar
Default Re: Post pictures of your first gen CR-V project.
Finally Got a New Camera...
New Camera = New Pics!
Old 02-20-2012, 01:21 PM
  #127
Phantastic's Avatar
jdmdrifter - what suspension are you using for your crv?
Old 02-20-2012, 02:08 PM
  #128
RevIllusions's Avatar
1999 Honda CRV EX 5speed
1994 B18C Cylinder Head
1994 B18B Short Block 81mm bore
Golden Eagle VTEC Conversion Kit
ARP Head Studs
Supertech Dual Valve Springs and Titanium Retainers
Wiseco 9.5 Flat top pistons
Eagle H Beam Connecting Rods
ACL/King Bearings
HKS Air Filter
Professional Products 68mm Throttle Body
Skunk2 Black Intake Manifold (port matched)
Skunk2 Cam Gears
Skunk2 Magentic Drain Plugs
Mishimoto Catch Can
ACT 6 Puck Clutch and Pressure Plate
NSX Calipers
TD05-18G Mitsubishi Turbo
GReddy Turbo Manifold and Downpipe
GReddy Front Mount Intercooler
Greddy Turbo Timer
Fast-Turbo turbo oil line upgrade kit
Custom 2.5 inch down pipe
Custom 2.5 inch test pipe
Custom 3.0 inch exhaust
Megan Racing MVO-T 3.0 inch muffler
Hondata 3 BAR Map Sensor
RC440 Injectors
Walboro 255 Fuel Pump
Hondata S300
Mishimoto Radiator and Fans
Autometer Boost Guage
Mugen FG360 Steering Wheel
Mugen Showa Shocks and Springs
RSX Type S wheels
Old 02-20-2012, 02:50 PM
  #129
LDForget's Avatar
sweet man, any idea how much power your making? AWD or FWD? How'd you route your exhaust if AWD? I routed my 3" on the drivers side.
Old 02-20-2012, 04:30 PM
  #130
pistol_p's Avatar
looks sick lowerd
Old 02-21-2012, 03:39 PM
  #131
JDMDrifter05's Avatar
If I recall correctly it is:
Front:
7in x 2.5in 600lb Eibach Spings 0700.250.0550
98-01 DC2 Type-R KYB AGX
97-01 CRV SPC Adjustable Ball joints
Grinded the UCA ends down smooth to avoid getting a control arm stuck, again
Rear:
8in x 2.5in 450lb Stance Springs
94 Eclipse GSX KYB AGX
97-01 CRV SPC EZ Arms
Custom Aluminum Strut Bushing
On a side note, I run with the fronts as firm as they go to avoid fender well rubbing and rears at the 2nd softest setting unless I have people in the back then I go to the 4th softest
Old 02-22-2012, 05:13 AM
  #132
KnightX's Avatar
here's my CRV (DD/beater)
Old 02-22-2012, 06:21 AM
  #133
LDForget's Avatar
Originally Posted by KnightX
You've got the same damn dent in the rear bumper as ive got. i cant wait to swap mine over from my parts CRV.
Old 02-22-2012, 07:02 AM
  #134
KnightX's Avatar
^^ LOL ive been too lazy to pop it out... i had that there since i picked up the car
Old 02-22-2012, 07:26 AM
  #135
LDForget's Avatar
Its not as easy as youd think. I even tried a heat gun to get it warmed up a bit, and it didnt pop out at all.
Old 02-22-2012, 08:03 AM
  #136
KnightX's Avatar
if it doesnt pop out then meh... doesnt really bother me lol
Old 04-06-2012, 08:35 PM
  #137
www.megameet.org's Avatar
I used a heat gun on mine ( same spot before i got the car), and pushed it out from the backside with a hammer. Not perfect, but not dented anymore
Old 05-11-2012, 07:20 AM
  #138
gxr154's Avatar
Here's a pic of my old 97 black awd crv auto i sold to a buddy of mine....dropped with 300 srt8 wheels...
Old 04-10-2015, 05:40 PM
  #139
fourbangerfan's Avatar
fast2camciv and preludepeterr, what did you use to lower you CRV? Also, what size tires are you running? Thanks in advance for any feedback. I'm very impressed with the CRVs on this post!
Old 04-13-2015, 09:01 AM
  #140
91 EF DX's Avatar
Picked this up 2 weeks ago. Only thing I've done is change the radio and put a hitch on it and bought a clock to go in it which I have yet to wire up. Thinking of lifting it or just putting some bigger tires on it.
Old 04-14-2015, 12:15 PM
  #141
Elvis Presley's Avatar
Howdy,
UK based new CR-V owner (1st Gen - 2000) and I'm looking forward to finding out all the stuff I should have found out about before I bought it.
I've been looking for something to help me negotiate some v.steep on-road hills (and the odd track) during my summer holidays in the mountains of Snowdonia. The CR-V seemed to fit the bill.
I'm a 48 yr old with a keen interest in all things car-related. Soft spot for Alfa Romeo. Considered a Suburu Forester/Outback or CR-V. Hopefully I've gone for the right one.
I'll do some searching of the DIY threads, and I might post the odd question.
All the best
Steve
I've been doing a few jobs....
Changed oil
air filter + cabin filter
fitted two sidelight bulbs
cleaned it in and out (smokers car previously)
changed trans fluid
changed 'stat
old air filter - Name:  air%20old_zpskbeyhxzn.jpg
not clean - Name:  DSC_0809_zpsoxqz4qvk.jpg
bumper was a lot goosed - Name:  DSC_0831_v1_zpssztckn3p.jpg
heat gun makes it a bit better? - Name:  bumpernow_zpsfukqgtgr.jpg
leak fixed - Name:  hose%20repair_zpsj36obhv0.jpg
ditched these Name:  DSC_0823_zpstwhzn9xs.jpg
for
front windows not working
relay ok
fuses ok
hmmmm
need to test switch and ground
Old 04-14-2015, 12:18 PM
  #142
oh and I dabbed a bit of solder about and that fixed the clock.
Thanks for reading.
Old 04-25-2015, 10:38 PM
  #143
98silverbullets's Avatar
Qu
Picking up my built B20z/vtec silverbullet and dropping off the b20b turbo project. 2 silver v's at the same damn time!
N/A B20z/vtec
Freshly built minty fresh
Old 04-26-2015, 05:46 PM
  #144
Skillachie's Avatar
Thanks a good looking engine bay right there
Old 06-27-2015, 12:04 AM
  #145
jc007_sr's Avatar
My 97 crv
Old 06-27-2015, 12:26 AM
  #146
jc007_sr's Avatar
Originally Posted by Elvis Presley
Howdy,
All the best
Steve
Changed oil
changed trans fluid
changed 'stat
old air filter -
not clean -
leak fixed -
ditched these
for
relay ok
fuses ok
hmmmm
Wires in between the door jam will be your problem. Did mines a couple months ago. Pain in the ash!!!!
Old 08-08-2015, 10:09 AM
  #147
Stygeon's Avatar
just wondering what you did for the vtec swap?
Old 03-01-2016, 04:52 PM
  #148
colinwerks's Avatar
Hi, New to the board here. This is my 97 V. Before and after. I put on some painted g35 wheels, lowered about 3", painted and coaxed an S2k Lip on it. Its my daily so i'm keeping it relatively simple for now.
Old 03-01-2016, 06:25 PM
  #149
Carbongoat's Avatar
Anyone have a diy on installing the accord fog lights?
Old 10-05-2017, 07:49 AM
  #150
Zack Richwine's Avatar
Mini range
Quick Reply: Post pictures of your first gen CR-V project.
