My 98 CRV Build, RT4WD Inside... - Page 5 - Honda-Tech - Honda Forum Discussion
Honda CR-V & Element 2WD & 4WD Element & CR-V
Old 02-13-2014, 09:42 AM
  #101
Default Re: My 98 CRV Build, RT4WD Inside...
I saw specs in this thread for the Civic Wagon manual trans gear ratios, but I didn't see any for the CRV. Anybody have the gear ratios for the CRV? Is it anything like the Integra LS trans? Just wondering how the revs are through the gears and on the highway.
DarryCar is offline
Old 02-15-2014, 05:52 AM
  #102
yusenglor's Avatar
Here's the gear ratios:
Gear ratios:
1st - 3.5
2nd - 1.956
3rd - 1.344
4th - 1.071
5th - 0.812
Final - 4.562
**Sourced from http://www.automobile-catalog.com/auta_details1.php**
yusenglor is offline
Old 02-19-2014, 02:17 PM
  #103
Thanks for the info. Looks like the gearing is a little higher than the Integra LS. There's a guy on eBay selling a CRV trans that looks like it has gears from a B16 trans, carbon synchros, and a custom fitted OBX LSD if anyone was interested.
DarryCar is offline
Old 04-10-2014, 06:21 PM
  #104
Awesome build, keep up the good work! and lots of GREAT info in here
Lowman is offline
Old 08-16-2014, 05:38 AM
  #105
Hi
any link to that gearbox or seller ???
davojuri is offline
Old 07-20-2016, 04:53 PM
  #106
Holy thread revival. Any updates on this thing?
dynamatt is offline
Old 12-15-2016, 03:59 PM
  #107
Gentlemen, does somebody know if this kind of self-made system is able to work? How to place it in so small gear house? There are oil pipes or combination of borings in body? Thank you in advance.
Russian tractor is offline
Old 05-31-2017, 03:02 PM
  #108
I also have a crv I want to go AWD but I keep hearing it's no use because of the rear axles or shaft that keeos going when racing tbem. Does the 03 crv rear axles and diff setup work better or is it the same result and they snap or brake all the time? Really want to k ow before I start Investing into it
Jamal Anderson is offline
Old 01-20-2018, 12:03 PM
  #109
Back from the death,
Congratulations, You just started searching the web and you've found the key to break an axle!
The snapping axle phenomenon is more common when things in the Honda differentials are welded, or using a Wagon (RTSI) stuff (different ratios), harder bushings, etc.
We rarely heard of a snapped axle in my country, my own set is a rusted to death, but still no play or any signs to give up.
CRV 2nd gen rear axles are slightly longer but not thicker. Looking at 3rd gen more of the same stuff. Not the one to say how much longer exactly. Look for rear track width for each vehicle and make you assumptions.
Be advised, if you lower the vehicle you may need a slightly longer axles to compensate the new operational angles under load.
With the Diff side, You can save all the biting hustle,
by using a newer model rear diff, I think all Honda 2005 (or was it 2008?)+ to 2012 models use an improved rear diff. and is fairly bolt on plug and play affair, Honda Pilot is a good bet.
D(from European HR-V), B and K series engines rear diffs have all the same gear ratio (as is the same rear diff (HR-V internally identical with +4 bolts)). I wouldn't suspect if the ridgeline too.
you can place a D series LSD and use Hybrid inner cv joint for some more fun, but for the love of metal, don't weld anything and don't expect all the power to go to the back.
Honda guys made it reliable, designed as help for ladies with no knowledge why winter tyres exists at all.
Good luck.
atanatas is offline
Emshhh
02-13-2018 03:23 PM
beeza
12-10-2017 06:17 PM
monster d
248
10-19-2017 10:24 AM
civicb20krt
Acura TSX
243
08-21-2017 01:06 PM
jmjcioffoletti
06-12-2016 06:47 AM
Quick Reply: My 98 CRV Build, RT4WD Inside...
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
