DIY: 2005 CRV Fog Lights instal with no switch
25 Attachment(s)
So today I got my fogs in the mail. Just some cheapo fog lights from ebay because on my good car I bought BNIB fogs from the dealership and 2 weeks later rock busted them and buy buy $300....
Here is what I got Attachment 446485 Attachment 446486 So lets get started. First thing pop your hood so you can get to the clips on the top Attachment 446487 Attachment 446488 Then turn your wheels to one side then the other so you can get these side screws out Attachment 446489 and the classic upper screws Attachment 446490 then all the pop screws underneath Attachment 446491 then with some force pop and pull the bumper off Attachment 446492 Attachment 446493 Now lay down some carpet and put your bumper down so you can start working on your foglights Attachment 446494 First using a razor and a dremel cut out the fog light housing Attachment 446495 Attachment 446496 then use sand paper to clean it up. Mine didn't come with a beauty trim but came with some rubber seal to place on the cut Attachment 446497 Now add your spring clips (3 on each side) Attachment 446498 and go ahead and mount your fog light Attachment 446499 beautiful Attachment 446500 Now for the wiring..... this bullshit ebay kit was so bad the switch literally did not fit! WTF?! So I wired it to not use a switch since I love foglights anyways... So first you need to stretch out your wiring and figure out your ground and power situation. For my ground I added the ground to the factory harness on the passenger side Attachment 446501 Then I found a place to mount my relay and fuse for power on the battery side... Attachment 446502 Then ran the power wire up to the battery Attachment 446503 Now to turn on our fogs.. I used the city light for an on switch. So first I unplugged the socket Attachment 446504 I was having a tough time getting to the wiring so I unplugged all the headlights so I could pull the harness down! Made a world of difference. Now I used a t-tap to tap into the power line of the socket Attachment 446505 Then taped it all up with electrical tape to clean it up and protect it! Attachment 446506 Now bolt it all back up and test it out!! no lights Attachment 446507 city lights on Attachment 446508 headlights on Attachment 446509 |
Re: DIY: 2005 CRV Fog Lights instal with no switch
Hey man this is great.. I got the bull shit ebay fogs too.. I get everything u said but uhh, which wire did u splice to connect to the city light using the t-tap?.. and as for the other plugs in the kit that u didnt use, do u just leave them dangling or wat.. thanks.
Awesome thread. Good work. I got aftermarket fogs for an '06 on ebay with a switch which also didn't fit, so I bought an OEM one which requires re-wiring to work with the ebay harness but haven't tried installing it yet.
I ended up getting morimoto LED fogs and wired them up similar to how you did- directly to the parking lights. That aside, I am curious about where the harness connects to the interior/cab & where to feed through the firewall. I've had a hell of a time trying to find pics on that. If anyone knows I'd appreciate it. |
https://cimg8.ibsrv.net/gimg/honda-t...5d27abcff8.jpg
I had a hard time getting the switch to work so I gave up on it and tapped the parking lights too. |
I was interested in getting the Winjet Fog Lamps too for my 2006 CRV SE. I assume you guys were trying to put the switch in the empty spot that is to the right of the Cruise Control Switch yet still left of the steering column? I know the switch spot to the right of the steering column is for the heated seat control.
The Winjet kit seems to be the only one that uses the standard Honda connector for the switch, incase it breaks just get a honda switch. I have a DEPO kit right now that came broken, seller refunded me and told me to keep. I was able to repair the broken brackets but I'm unsure if I want to wait til install day to find out if it works. The DEPO kit like many others, comes with a switch that looks nothing like factory and the connector is universal so if it breaks, your SOL. |
Actually Nevermind. I've been digging up pictures of the Winjet kit, the Factory Switch, and the Depo Kit and came to the conclusion that the Winjet kit doesn't even use a factory style harness. The connector that I thought was factory because it was green and resembled the factory shape actually isn't correct. The factory plug is keyed and blue. I think I'll stick with DEPO kit. Hopefully my repair job aligns correctly.
sry to bring this thread up but I was wondering is this the oem fog lamp switch for the cr v? im trying to install fog light in my 05 cr v too.
Genuine Honda 08V31-S9A-61135 Fog Light Switch |
Originally Posted by xylium
(Post 50967034)
Hi, i have a Honda CR-V 2006, and just want to know what means "DEPO KIT" Because i bought Fog lights too from ebay, and don't want problems to install them. Thank's |
Just ordered my foglights, let's see if I can make this work...
Originally Posted by Caoboy
(Post 51186406)
TBH I have no idea which kit I ordered. It was cheap on an eBay auction and I ended up winning it for $30
Mainly bought it for the housings and worst case I'll make my own harness and just connect it like this write up shows. I've also seen the EK fog light write-up which uses an OEM switch, I've wondered if we can also use OEM harnesses in the body harness like that write-up does. |
Yeah, seems like all those eBay kits are the same shit different labels. Let us know it turns out cause the front bumper looks naked without fogs and that's next on my to-do list.
Also, if you don't mind, can you PM me pics of the plug end that plugs into the switch? |
Update, it's a Spec D Tuning kit.
There are no instructions :thud: |
Cao, what route did you end up going with the wiring?
Followed OP's route.
The switch also didn't fit, which is why. As an added bonus, when locking and unlocking, the fogs flash as well, helping the blind find their car in the dark ;) |
don't people use other Honda fog light switch to make it fit?
Other people have used a factory fog light switch.
I do not have one on hand, so I do not know if it would work with the aftermarket wiring. If I were to go the factory switch route, I'd find a wrecked CRV and pull the factory fog light wiring harnesses out and use those, ensuring it's wired properly... |
have anybody ran the wire harness through the firewall and if you or anybody that you know can you post a picture of with way you went thought also have mines with the running lights but i would like to use the switch that came with,please post pictures if you have, thank you in advance
Question, are these cars prewired for fogs?
edit: never mind, cao just told me that it's not prewired. I guess I'll order the eBay kit and use their harness and try to splice it into the oem switch&pigtail that I just got from the yard off an 02 but I own an 05. |
Thank you for all the info i able to install the lights i connect it to the headlight wire,it not perfect but good enough 👍🏻 |
Anyone know if you can switch the 05-06 bumpers with round lights for the 02-04 bumpers with rectangle lights?
You have to change the headlights and front grille. Maybe the fenders as well but I’m not sure on that. |
Originally Posted by Type-Spaz
(Post 47263466)
Post a pic of the bracket.
I think I threw them out. Didn't need them, I mounted mine like the OP. |
