Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 Honda CR-V 0132 code
Old 05-20-2018, 12:50 PM
elo2009's Avatar
Icon5 1999 Honda CR-V 0132 code
Hello, I have a 1999 honda CR-V with a JDM b20 engine swap. I am getting a 0132 code (Sensor Circuit High Voltage bank 1 sensor 1) I already changed both 02 sensors and check the wiring harness. I am thinking this could be an issue with the ECU? Anyone have any ideas as to what it can be causing this or what i can do to fix this code? Thank you.
Old 05-21-2018, 09:21 AM
UK-Kev's Avatar
Default Re: 1999 Honda CR-V 0132 code
I would suggest you check the voltage O2 sensor one first and let us know what voltage you have.
Also have you reset the code to see if it comes back?
kuks24
11
06-24-2019 04:59 AM
Civiccity03
Honda Civic (2001 - 2005)
12-17-2014 11:36 AM
Acdmx42
03-18-2013 02:18 PM
Quick Reply: 1999 Honda CR-V 0132 code
