CR-V B20Z from Croatia
#59
Re: CR-V B20Z from Croatia
So e New stuff ready for installation
Rear 7x18" spare tire
All collor matched-white
UltraRacing real lower tie bar With red washers from MPC
Some New red washers
Some New smoke/red tailoghts
MPC billet drop forks to be installed
#60
MPC drop forks doesn't work With OE suspension-by lifting the car it hits driveshafts. They didn't stated it anywhere. I returned the forks and got refund. To much trouble. Every bump on the road causing the car to jump or slight ofroad drive will make fatal impact between fork and driveshaft
#61
On the other hand 1320 performance exhaust manifold and 2.5" cstless back system is Great. Flawless installation!!!! Great Sound, throttle response and noticea
Packed properly. No bents and damages at all
Note red washers on front LCA😉
ble Power and torque increase. Did use allen bolts With red washers
#64
Some new stuff arived and ready for installation:
1. Truhart upper control arms
2. Hardrace reinforced tie rods
3. Skunk2 pro billet 70mm TB and thermal gasket
4. Downstar bolts + red washers
-transmission
-mounts
-steering rack
-front LCA
-front UCA
-rear whole subfrsme
-transmission
-mounts
-steering rack
-front LCA
-front UCA
#67
Refreshed grille-glossy black and white-waiting for EDM amblem again. Classy look
New trunk amblem from accord. Like it much more With 3D transparent cover than those flat red aftermarket ones
Rear bumper lamps and reg plate carirer not any more black plastic
#72
Left for installation:
1. Complete transmission bolts and red washers
2. Complete motor mounts bolts and red washers
3. 1320 billet engine mounts
4. 1320 billet postmount
5. Skunk2 billet 70mm TB
6. Integra LS new TB cable
#74
